586,754 active members*
7,474 visitors online*
    Dec 2017
    47
    Resolution problem
    Have a diy engraver, using nema 34 motors and cw8060 drivers, machine responds fine, but I have a problem with the output. If I send a perfect circle, it cuts an oblong. Does the same with every object I send. Somehow the length and width does not correspond to the object I send. I have tried several software programs and all do the same
    thing, so it is not the software. Hope someone can help me with this, thanx!
    Jun 2011
    692
    Re: Resolution problem
    What is your controller? It's probably a setting in there.
    Apr 2003
    540
    If it's not binding and you're not loosing steps then it could be a couple of things.
    - One of the drivers for the X or Y has the incorrect dip switch settings (microsteps) or simply differs from the other.
    - The steps per units for either your x or y (or both) are not set to the correct amount.
    - (Less likely) - The settings in your driver software (mach3?) on how to handle arcs is not correct (CV etc) which differs based on your cad/cam post gcode output. Which if not set correctly can cause some strange things to happen.
    Good luck.
    Dec 2017
    47
    Thanks, I have resolved the problem gcode settings, apparently there was no exact setting on my controllers, so I had to do it with the $111=n setting until I achieved the desired result, thanks again!
  1. Screen resolution problem
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-10-2011, 02:04 AM
  2. how much resolution do I need?
    By jrz126 in forum CNC Machine Related Electronics
    Last Post: 01-13-2011, 01:51 AM
  3. Resolution
    By Allan in forum Linear and Rotary Motion
    Last Post: 10-27-2009, 09:38 PM
  4. CNC resolution
    By sinha_nsit in forum Mechanical Calculations/Engineering Design
    Last Post: 10-22-2008, 10:11 AM
  5. Resolution
    By Laff Riot in forum CNC Machine Related Electronics
    Last Post: 05-29-2003, 08:03 PM
