586,032 active members*
2,874 visitors online*
IndustryArena Forum > CAD Software > Logic Trace CNC/DXF > logic trace 2018 digitizing a clock diagram and building the project
Results 1 to 1 of 1
    Oct 2007
    1022
    I found a small diagram on a unique clock dial and used
    logic trace 2018 to digitize the diagram and enlarge it
    full size
    for a large clock project .
    The dial was cut by a plasma operator and the wood parts were cut with the cnc
    I also cut he file on a CO2 laser to show that the file is easily used
    by either machine
    https://youtu.be/x_Z_r02Ca2c part1 took a small diagram of a clock dial and digitized it
    https://youtu.be/Q1u_JG7akbI part 2 this is the plasma cut of the dial and cnc machining
    Attached Thumbnails Attached Thumbnails IMG_3641.jpg   temp assemble.jpg   IMG_3659.jpg
  1. logic Trace 2018 summary of the upgrade
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 11-08-2018, 09:04 AM
  2. Logic Trace 2018 re-scale a project drawing
    Last Post: 10-04-2018, 08:20 PM
  3. Logic Trace 2018 mirror image selection
    Last Post: 10-04-2018, 07:32 PM
  4. logic trace 2018 using autoscale selection
    Last Post: 10-04-2018, 06:52 PM
  5. logic trace 2018 difference between the pen and cursor
    Last Post: 09-30-2018, 07:28 PM
