586,094 active members*
4,177 visitors online*
    Aug 2015
    Is my Ruida controller acting up?
    I'm having a problem with my Red and Black lasercutter. The head is not responding to using the controller arrows. It fires, cuts etc, but when I hit the arrows it just moves a tiny bit every time it's pressed. Is the controller flaky or could it be something else?
    Oct 2015
    96
    Re: Is my Ruida controller acting up?
    Membrane switches used in Ruida controller are poor quality. You can buy replacement, but it will fail again in time. I have prepared switch-panel with micro switches, NOT finished/soldered yet, as my own is still working. You can try to reconnect panel band inside controller (kind of connectors) - access is not very bad, but don't forget disconnect power to laser as there are main power close, don't be electrocuted.
    Alternatively or for temporary help you can use Ruida android application to control your laser - but you have to use home router/wifi (see bialy100k video @ Youtube) and your Ruida firmware have to be comparably new (version over x.x.50 if I good remember).
    Polish @ Éire
  1. replace leetro controller with ruida 6442g
    By Hydrops in forum Laser Control Software
    Last Post: 04-23-2019, 12:21 AM
  2. What is the difference between a Ruida RDC6332G and RDC6442G controller?
    By AdrianPage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-07-2018, 05:42 PM
  3. Ruida Controller Crashed
    By paudyh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-19-2018, 01:02 AM
  4. Ruida controller and software
    By djmunt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2017, 05:11 PM
  5. Which controller to go for: Leetro 6585, Ruida, AWC708C lite?
    By mrveenie in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2015, 10:45 AM
