Hi Every One
During tool change spindle is not at basic orientation position the deference is approximately 120 degree
How can fixed the position or error
any idea
Thamks in advance
Rana Ali
Hi Every One
any idea
Thamks in advance
Rana Ali
Go into CNC ISO page, MENU SELECT - STARTUP/SETUP - SET PASSWORD (SUNRISE) - MACHINE DATA - AXIS MACHINE DATA / AXIS MD (select spindle using vertical AXIS + / AXIS - keys), search for 34090(0) and add / subtract offset to figure already in there working on 0 as a minimum, 360 as a maximum), press input then vertical key SET MD ACTIVE. Power down, re reference, check spindle orientation, adjust and repeat until it's right.
