What is the format for the G10 on a Mazak lathe?
What control? Mazak use Mitsubishi, Fanuc, Yasnac.
Al.
Albert E.
OK Mazak predominatly used Mitsubishi, if you need a manual, look for a system number on the top of the controller rack, like M300,M550, M50 etc,
Go to the MEAU site and download the operator manual.
If it is a Fanuc 0, I can send it in PDF.
Al.
Albert E.
For a 640T:
G10 L10--Programmed Tool Offest Input
G10 L10 P_X_(U_)Z_(W_)Y_(V_)R_(C_)Q_;
P offest #
X x axis offset , absolute
U x axis offset, incremental
Z z axis offest, absolute
W z axis offset, incr.
Y y axis offset, abs
V y axis offset, incr.
R tool nose rad comp amount , abs.
C tool nose rad comp amount, incr.
Q Hypothetical tool nose point
L value is optional
G11 cancels
