586,100 active members*
3,034 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Screen Fading in and Out
    Hi I have got an annoying issue on my VMC 3016 with the CNC 88HS control, the CRT Monitor is periodically fading in brightness to near invisibility then will come back to full brightness, there doesn't seem to be any obvious cycle time or cause, i was debating swapping to an LCD screen but was wondering if this could be a controller issue?
    Jan 2014
    20
    Re: Screen Fading in and Out
    There are adjustment pots inside the pendant for brightness, screen size, contrast......
    I expect one of those are dirty or moving from machine vibrations.
    Check your incoming power to the CRT when it fades out and see if you still have 115VAC on it. This will rule out the power in. I agree with the adjustment pots. Turn each of them one complete turn then turn them back. This should clean the pots enough to be consistent with the monitor on. If you are still having issues, re-seat your graphics card and make sure all the connectors are tight. If all was checked and good, then it is time to replace your monitor. We have an LCD replacement (ELE-0190) that should clear your problem up.
    FadalCNC Tech Support
    Thanks all, looks like the pot trick has worked, fingers crossed!
  1. Need help - laser fading in middle of engraving section
    By txmit1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-23-2018, 07:48 AM
  2. Replies: 1
    Last Post: 02-05-2018, 07:46 PM
  3. Fast power fading on laser cutter
    By Frozen.Q in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2012, 08:28 AM
  4. VF3 Monitor Fading Out
    By phoodieman in forum Haas Mills
    Last Post: 06-09-2011, 05:26 PM
