586,069 active members*
3,410 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Doubt about internal spindle wire size
    Apr 2016
    Question Doubt about internal spindle wire size
    Hi guys, i hope somebody can solve my doubt. I bought a tipical chinese spindle for my new cnc build, and when open it for adding a wire for ground the body, found that internall wires are too thin. I was thinking about use 14 awg shieldied wire from VFD to spindle , but after see the size of internal wire I have the doubt about how much sense have it if the internal wire looks like a 18 awg.
    I took a picture , the green wire is a 14 awg that i added for ground the body.
    What do you think? have sense use 14 awg wire or is just a waste if the internal wire is so thin?
    Sorry about my english, it is not my native language.
    Jul 2014
    63
    Re: Doubt about internal spindle wire size
    Use the thicker wire! The resistance on smaller wire over a few inches isn't a big deal (as long as it can handle the current) but the voltage drop due to the resistance you could get on 10-20 feet of thin wire might make a difference.
    Sent from my SM-G960U using Tapatalk
    Apr 2016
    That have a lot of sense, I think this thread is solved.
    Thanx Rich! :cheers:
  1. Replies: 7
    Last Post: 12-09-2015, 09:49 AM
  2. Via shape/size and wire size.
    By Drools in forum PCB milling
    Last Post: 08-14-2009, 03:47 PM
  3. Wire EDM - Wire Type and Size
    By greenchair in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2009, 07:44 PM
  4. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  5. Doubt about X2 spindle
    By mugabe in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2007, 01:48 PM
