586,104 active members*
3,510 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need Help! Fanuc Alarm 1400, 607, 613, 9004
Results 1 to 8 of 8
    Sep 2018
    38
    Machine: 2008 Sharp SV-2412
    Control: Fanuc Oi Mate-MC
    Alarms: 1400 SPINDLE ALARM
    607 X AXIS:CNV. SINGLE PHASE FAILURE
    613 X AXIS:CNV. SINGLE PHASE FAILURE
    607 Y AXIS:CNV. SINGLE PHASE FAILURE
    613 Y AXIS:CNV. SINGLE PHASE FAILURE
    607 Z AXIS:CNV. SINGLE PHASE FAILURE
    613 Z AXIS:CNV. SINGLE PHASE FAILURE
    9004 SPN 1 :INPUT FUSE/POWER FAULT
    I boot up normally, get the 607 and 613 codes, then after maybe 20 seconds a breaker trips and I get the 9004 code. The servo drive has a normal status until the 9004 code trips, then the LED on the servo drive gives ALARM 04.
    Any thoughts on how to diagnose this? I was making chips last night, nothing out of the ordinary. I power up this morning and this is what I get.
    Thanks for any advice,
    Max
    Sep 2018
    38
    Re: Need Help! Fanuc Alarm 1400, 607, 613, 9004
    Here's a video of what happens after I click off the E-Stop. As soon as I turn off E-Stop, the control tries to send power to servos etc and then I get alarms 1400, 607, 613. After about 20-30 seconds the breaker/switch pops and I get Alarm 9004. The popping switch scared me a little bit lol
    https://www.youtube.com/watch?v=tMI6sbZCBKI
    Here's a video of the servo unit. Is the sound coming from the box normal? It's made that sound since I purchased it a couple months ago.
    This is a common issue within the power supply section of that unit. If you would like to give us (Tri Star CNC Services) a call at 815-578-9145 we can discuss it further.
    https://www.tristarcnc.com
    We offer free phone support to help you troubleshoot
    815-578-9145
    Jan 2020
    Quote Originally Posted by MaxWeber View Post
    https://www.youtube.com/watch?v=tuMQ01gzoBc
    Hello sir ,I'm also facing the same issue please help me with a video clip
    Im having the same issue to with the same alarms. How can i fix this.
    Sep 2018
    38
    Quote Originally Posted by Noelantonio View Post
    It ended up being a bad power supply board that had to be reworked. TriStar CNC performed the repair. Some bad resistors on the dc circuit close to the lugs.
    Ok so,
    Is that board is removable and can be fix by them or just need a new one?
    Also , what do you mean by the Lugs?
  1. Alarm 9004....need help
    By mattpatt in forum Fanuc
    Last Post: 02-09-2021, 07:40 AM
  2. Need Help! Fanuc Alarm 1400, 607, 613, 9004
    By MaxWeber in forum Fanuc
    Last Post: 11-04-2018, 06:10 PM
  3. 1400-5A vs 1400-5C CPU board
    By goveng in forum Fadal
    Last Post: 04-17-2018, 10:28 AM
  4. More blocks/sec from a 1400-5 vs. 1400-4?
    By mflux_gamblej in forum Fadal
    Last Post: 06-27-2017, 03:58 PM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
