586,094 active members*
4,050 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Tool change height incorrect. Bridgeport Interact 520 Vmc
Results 1 to 2 of 2
    Exclamation Tool change height incorrect. Bridgeport Interact 520 Vmc
    Hi, I have a Bridgeport interact 520 VMC with heidenhain TNC 155 control. I have various issues with the machine; Sticky limit switches, Buffer battery and parameters, dodgy Z axis encoder all of which have been overcome.
    I have written some basic programs and all the axis are operational as is the spindle.
    The problem I have now is the tool change height is incorrect. No matter what I change the parameter to the control indicates that the Z-axis has moved to 0.000 for the tool change. As it turns out I need the Z-axis to be at about -7.9mm to be at the correct height.
    I have set the positive Z limit to be ~+7mm and the tool change height to be -7.9 but the machine always goes to 0.000 regardless.
    Anybody experience a similar problem and know how to overcome it?
    Many thanks,
    WB
    May 2016
    526
    Re: Tool change height incorrect. Bridgeport Interact 520 Vmc
    We would need to see your program
  1. Arrow 500 tool change height
    By Slick27 in forum Cincinnati CNC
    Last Post: 08-04-2015, 03:11 AM
  2. m998 tool change height bug?
    By tmarks11 in forum Tormach PathPilot™
    Last Post: 07-06-2015, 01:40 AM
  3. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
  4. Replies: 3
    Last Post: 05-28-2009, 01:16 AM
  5. BMC-10 tool change height
    By leggetmachine in forum HURCO
    Last Post: 07-31-2007, 03:45 AM
