Just like title says, I need help on figuring out steps for my x axis for my router(still in building stage). I didnt have any problems with my z, but x is giving me headaches.
I'm using Keling steppers, which then connect to 16 tooth 5mm timing gear which than belt drives 48 tooth gear which than turn 20 tooth spur gear which moves the gantry on gear rack.
So i would really appreciate help with calculating steps for this setup so i can start playing with motors turning
The gear rack has 5 teeth per inch(i believe). The drives are currently set for 1/8 microstepping.
Thanks in advance for any help!
