586,114 active members*
3,168 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Tool Nose Radius Comp Calculator (only G1)
Results 1 to 13 of 13
    Aug 2011
    419
    I would appreciate if you try and comment.
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    Re: Tool Nose Radius Comp Calculator (only G1)
    hello if you wish to provide an alternative, and people to use it, it must behave faster than whatever it is out there, or at least faster the common methods, and more affordable comparing it to specialized methods ...
    for example : if someone enters all those coordiantes inside igf, will definetly get the code faster
    yes, you can do the math, but, you need to beat current methods
    xls is ok for some stuff, but for rad comp, igf is faster ...
    think about a method that is faster than igf, like an okuma dedicated G-code converter, with fast cad
    / kindly
    Aug 2011
    419
    if control unit hasn't radius comp spec, you can't use G41 or G42 codes.
    IGF generate code with G41 or G42.
    Some control units may not support radius compensation.
    and igf is not installed in some control units.
    Jun 2015
    4154
    aha, i see : what do you think about a macro inside autoCAD ? thus to draw it there, click a button, choose radius + P, and generate compensated code ?
    Aug 2011
    419
    It's possible but i can't.
    I don't know the LISP.
    Jun 2015
    4154
    find a sexy L . I . S . P teacher; she will help you, unless you don't alter the deal
    or try your luck with software dealer ?
    with help from a trained person, i guess this could be done in a few days
    until then, stick to xls / kindly
    Jun 2015
    4154
    let's try asking here :
    ... https://www.cnczone.com/forums/autodesk/
    ... https://www.cnczone.com/forums/autodesk-cam/
    or on an oficial autodesk/autocad forum ? maybe someone has a clue about how to do it
    Jun 2015
    4154
    hello again, i have looked a bit more over your xls
    you definetly need a more performant coding enviroment
    i mean, even if it works, i believe that you can do much more than that
    also, i really don't know how many people will actually use it ...
    somehow i also deal with the same thing, but i develop most of the stuff for my self, and, for now, i don't bother if someone else uses another method ... i don't know ...
    this is a bit high-specific
    about using macro inside autocad, i have my own cad, and it is working nice for 2d toolptahs, but, in the end, you have to think about the goal that you are after ... at this moment i don't really have time to show my methods, even if i know that some of them are fast ... all i wish is to improve my level, and deliver things faster ...
    you are pretty good with osp encription
    at some moment you have to decide if you wish to use your custom tools for youself, or try to convice others to also use your tools ... convincing others to change their approach requires patiance and skill / just saying
    Jun 2015
    4154
    this is a part of what i do, but is not my single approach for comp codes
    toolpath code is put inside a turning template, which has translations factors, accordingly to desired comp quadrant
    file is sent to the machine
    at the machine i select and run the program, but, for the future, i wish only to run the program, not also to select it, but at this moment i don't know how to do this
    for common stuff, it is pretty fast / kindly
    Jun 2015
    4154
    specific parameters are interfaced via dedicated software
    this makes life easier for operators, and the source is capable of custom post-processing
    code goes to the radial turret lathe, or to the mill, or to a cnc <> okuma
    Sep 2010
    1230
    Quote Originally Posted by kurmay View Post
    Hello kurmay,
    I haven't waded through your math, but at a glance at the Part Profile and the Post Output (see attached below),
    Attachment 406470
    I can't see how you get there. The Radius of the Tool and how the tool is set (Orientation - Tool Type) have to be considered; I don't see where this has been specified.
    Following is a line drawing using your Profile Points.
    Attachment 406472
    Given that you're using G42 in your example, the Tool Path is for an OD Turning Operation. The move from X100 Z850 to X200 Z 850 is perpendicular to the Machine's Centre Line, therefore, there will be no Offset in Z for that move. Accordingly, if a typical OD Turning Tool set by the Leading Edge of the Cutting Insert in Z and the point on the Insert closest to the Machine Centre Line in X is used, then the Z coordinate for this move will be Z850. However, your example shows a Z output for this move as Z870, suggesting that at least the Centre of the TNR in Z is being used with a TNR of 20. This logic doesn't work with subsequent moves. Perhaps you can step the Forum through how you arrived at the Output you have?
    Regards,
    Bill
    Aug 2011
    419
    You must look TOOL DATA section on bottom of excel spreadsheet
    Sep 2010
    1230
    Hello kurmay,
    OK, I see that now. However, as stated in my previous Post, G42 and the direction of travel defined by the profile points indicates an OD Turning Op, one in which setting the tool as P1 would be rather obscure; hence my difficulty in reconciling your Post Output values.
    Regards,
    Bill
  1. Tool Nose Radius comp on 840D
    By shags72 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-14-2012, 08:22 PM
  2. Tool Nose Radius Comp
    By lukehonor in forum G-Code Programing
    Last Post: 12-27-2010, 11:22 PM
  3. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  4. Tool nose radius comp. help needed
    By cuz1007 in forum G-Code Programing
    Last Post: 01-20-2010, 08:15 PM
  5. Help with tool nose radius comp
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-09-2008, 02:25 PM
