586,113 active members*
3,242 visitors online*
Thread: Mirror axis
Results 1 to 7 of 7
    Jun 2006
    48
    Mirror axis
    is there a way to mirror axis (Y-axis) in RhinoCAM post generator? So now in output I have positive Y but would like to have negative (same value, but negative).
    Jun 2005
    1730
    Re: Mirror axis
    You might want to mirror the Y axis in our CAD drawing and then post it again and it should work correctly.
    Russ
    Jun 2006
    48
    Re: Mirror axis
    Mirroring ni CAD is not a good solution in my case, would be much happier if that would be done in by post processor, if possibe.
    Apr 2004
    5737
    Re: Mirror axis
    I don't see why mirroring the part in CAD wouldn't work for you, but I suppose you could configure a post that switched all the positive Y values to negative ones. Or do it in the CNC control program (Mach3 or whatever your machine uses) - remembering to switch it back when you wanted to make a regular part.
    Andrew Werby
    Website
    Jun 2006
    48
    Re: Mirror axis
    I'm doing some tests on woodworking cnc machine where coordinate system is rotated by 180deg arround X-axis, that means also Z axis is pointed downwards...
    So, anyone know how to flip those coordinates by post?
    Mar 2010
    99
    Re: Mirror axis
    You can only rotate axis direction.
    Double click on Setup icon in TP tree, there you can see "rotate about" option.
    To set Z axis down, you need change Spin angle to 180 and click on appropriate axis button to rotate.
    Bad news is other axis will change too.
    I guess you can set Z downwards without XY direction change, if you choose right machine.
    I don't know how choose it manually, try load new machine configuration and see by yourself.
    Apr 2003
    1357
    Re: Mirror axis
    You can easily do a mirror post. I have posts mirrored in X and posts mirrored in Y. We use them everyday without issues.
    Just go to the motion tab in the post generator and use a negative scale factor for the axis you want to mirror. For example Y would be -1 in your case.
    If you want to maintain a cut direction, such as climb milling, then you would need to calculate your path to cut conventional, then when you mirror it, it will climb. Also remember that any engraved text will need to be mirrored in CAD ahead of time, as the mirrored post will mirror that too. The image below shows the X axis mirrored.
    Hope this helps,
    Dan
  1. Replies: 0
    Last Post: 08-24-2018, 09:49 AM
  2. Laser engraver mirror align- beam hitting side of mirror
    By dreamchasertx in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-09-2017, 06:43 PM
  3. MIRROR AXIS POSITION
    By roberton26 in forum Fanuc
    Last Post: 06-10-2015, 01:01 PM
  4. Way to take gcode for one axis and mirror it for another axis?
    By genestapp in forum Uncategorised CAM Discussion
    Last Post: 10-09-2010, 04:14 PM
  5. Mirror image C-axis.
    By M-man in forum Daewoo/Doosan
    Last Post: 02-06-2007, 06:35 PM
