586,912 active members*
3,594 visitors online*
Results 1 to 11 of 11
    Dec 2014
    35
    AUTO ZERO TOOL FOR MACH3 CNC ROUTER
    Hello Gents
    I purchased a Tool Setter Touch plate, which did not have a script file attached to it. The total thickness is 19.76 mm.
    Any idea where a suitable vbscript file, may be downloaded and this thickness measurement can be edited in it?
    This is required for my MACH3 controlled cnc router.
    Regards
    Craig
    Re: AUTO ZERO TOOL FOR MACH3 CNC ROUTER
    Google "Mach3 Auto Zero Script".
    Dec 2014
    35
    Hello ger21
    Thank you for your response. I found what I was looking for, which was a link from a video clip. The link was not available anymore, but as you said, a Google search will find it. I found one and installed it. It works for sure.
    Regards
    Craig
    Dec 2014
    35
    Hi Gents
    I had the auto tool set working well on my MACH3 controlled router. All of a sudden, it gives an error message, when clicking on the AUTO TOOL ZERO icon in MACH3. Error in script .in. I don`t know what they are referring to? The licensed version of MACH3, which I am using is R3.043.062
    A Google search enabled me to find a vbscript file and the measurements are in IMPERIAL.
    What is the correct way of entering a METRIC number into the vbscript? Must a mm be typed after the numerical figure, with a space or not?
    Regards
    Craig
    The script does not know or care what units you are using.
    I think the error message is just cropped, so it's hard to say what it's referring to.
    But there must be some type of syntax or other error.
    Dec 2014
    35
    Hello Gerry
    This is so frustrating. If I tap on the DEBUG icon on the vbscript folder, there is a F7 and F8 tab. After selecting either one of them, the script re-opens and the (mm) is HIGHLIGHTED after the plate thickness. Its as if its trying to tell me something, regarding the METRIC letters. I could be wrong?
    If I leave the vbscript exactly as it is (GURU) on YouTube version, it works, BUT it lowers down onto the touch plate and carries on as if its a hydraulic press. I just have to hit the Emergency stop.
    Regards
    Craig
    Dec 2014
    35
    Hi Gerry
    All this trouble started after connecting a remote USB pendant, bought on eBay. It worked until I discovered that the Auto Tool Zero went bonkers. So left the pendant alone, as it started this problem.
    Apr 2014
    215
    Can you not post the script here, you may need to call it *.txt
    Dec 2014
    35
    Hello robertspark
    I will try to post the script, which I used.
    Dec 2014
    35
    Hello Gents
    The attached script is working, but I need to change the plate thickness of ( 2, 060 ) to a Metric measurement of 19.76 mm.
    G31Z-4.F4
    Z-4 Direction of Z - travel to minus
    F4 Feed rate
    F50 around half of feed rate
    Regards
    Craig
    Dec 2014
    35
    Problem solved and tested.
  1. Auto tool zero doesn't stop in Auto Tool Zero routine on Mach3
    By Flintstone in forum WoodWorking Topics
    Last Post: 09-05-2017, 07:00 PM
  2. MACH3 AUTO TOOL ZERO MACRO
    By ZZRBlokey in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2015, 06:57 PM
  3. Mach3 ATC & Auto Tool Zero
    By KNA in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2015, 10:16 PM
  4. Replies: 0
    Last Post: 09-01-2014, 06:20 AM
  5. Ayuda con Auto Tool Zero en Mach3
    By hmoltedo in forum Spanish
    Last Post: 12-06-2011, 02:58 AM
