586,119 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach 770 Modular Mill Surface finish
    Nov 2018
    12
    Hi Folks,
    Tormach 770, using the module 25mm endmill with tormach steel cutting inserts. I am working on dialing the program in for surface finish with poor results. I seem to have chatter maybe? it sounds ok when cutting, loud but no squealing. A-2 material, .060" DOC, .1" stepover, 1600 RPM, 18 IPM. Image attached, Thoughts?
    Jul 2004
    1424
    Re: Tormach 770 Modular Mill Surface finish
    Can you physically feel any of those marks? If you drag your fingernail across the workpiece, can you feel any ridges?
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Feb 2006
    7063
    If you want a good surface finish, you would normally do a very shallow finish cut - typically no more than 0.005-0.010 DOC". You should likely also be feeding faster on the finish cut, to compensate for chip thinning. Assuming it's a 2-insert tool, 0.01" DOC, 0.1" WOC, I'd be running ~1300 RPM, 44 IPM. Are you using coolant? If not, you really should be. If so, what kind - flood? mist?
    I find I get a really nice finish on most metals using HSM techniques - narrow WOC (usually ~0.05", and high speed). I would try 0.05" WOC, 1300 RPM, 60 IPM, using a Facing operation and only climb-cutting. This should give a good finish even with your 0.06" DOC. You MUST have coolant to do this.
    Regards,
    Ray L.
    Nov 2018
    12
    Yes you can for sure feel them. Its a 3 insert cutting tool. using flood coolant. i was hoping to reduce the cycle time, but i guess it beats hand lapping. 2d adaptive toolpath, ill give a finish pass a shot. thanks guys
    Feb 2006
    7063
    Quote Originally Posted by legacymachining View Post
    Adaptive is not always the best for finishing - it's really intended for fast roughing. With 3 inserts, and 0.050" WOC, you should be able to run almost 90 IPM using a constant-engagement facing toolpath, and get a lovely finish.
    Regards,
    Ray L.
  1. CNC'd LMS High Torque Mill Surface Finish Question
    By LilHalfSquat in forum Uncategorised MetalWorking Machines
    Last Post: 09-02-2015, 06:32 PM
  2. CNC'd LMS High Torque Mill Surface Finish Question
    By LilHalfSquat in forum Benchtop Machines
    Last Post: 08-31-2015, 02:48 PM
  3. Diamond cut end mill surface finish
    By geroge in forum Hobby Discussion
    Last Post: 05-01-2015, 12:32 AM
  4. Surface finish engraving with drill point end mill
    By Brian Corwin in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2014, 03:35 PM
  5. surface finish with a ball mill
    By david rendon in forum CNC Tooling
    Last Post: 05-26-2011, 03:50 PM
