586,106 active members*
2,984 visitors online*
    Mar 2012
    27
    AWC708L; Connections to Laser Power Supply
    I've looked at a raft of connection diagrams for controllers and laser power supplies and haven't found exactly what I'm looking for. Is it possible to have a manual momentary switch connected between HL to IN on the pwer supply while you have all the other connections in place? I want to be able to fire the laser without the controller on. However, won't be using this switch with the controller energized. What I need to know is how will this connection interfere when the controller is on? Not an electronic whiz, but I know enough to get in trouble here. I've included a diagram of my AWC708L to Laser supply connection diagram. Is there anyone that can see a problem with this setup?
    Thanks in advance for any help.
    Attachment 405826
    Nov 2008
    643
    Re: AWC708L; Connections to Laser Power Supply
    P to ground and H to 5v will turn it on but IN controls the power. Low voltage won’t energize the beam. Too high will overpower it. You could guess and drive it with a variable supply starting at about a volt. Don’t run it without water
    Mar 2012
    27
    Thanks for the response. Could I install the typical pot between 5V IN and Grnd to control power. What do you mean P to ground and H to 5V will turn it on. Should I have a DPST switch to control each line simultaneously? Thanks for your help.
    Nov 2008
    643
    P to Ground means connect P to Ground which tells the controller that water is on. H to 5V tells the controller to fire. you can put this one on a momentary switch.
    you want to use your pot to create a voltage that goes between 0 and 5 volts by creating a voltage divider circuit. you supply a 5 volts in and the output of the circuit is a ranges between some low and high number not over 5. you don't need a switch on this line. you can buy a cheap circuit that tells you how much power, in milliamps, is going thru the tube. its not precise but helps you from overdriving the tube.
  1. 50 Watt Power supply connections question
    By Devoreg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2016, 05:30 AM
  2. China laser power supply connections
    By Billn in forum Laser Hardware
    Last Post: 01-23-2016, 05:47 PM
  3. Hurricane Laser Connections and power requirements
    By cdmcali in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-30-2012, 04:33 PM
  4. Chinese Power Supply connections
    By thudson in forum CNC Machine Related Electronics
    Last Post: 03-20-2010, 04:29 AM
  5. Keling motors, drivers and power supply connections
    By Nitroghost in forum Automation Technology Products
    Last Post: 03-13-2008, 05:18 PM
