586,234 active members*
2,972 visitors online*
    Aug 2017
    112
    How to get and set offsets for U and V axes
    Dear all
    I am using kflop motion board and KMotionCNC.
    In that software as i have seen that in fixture offset table X,Y,Z,A,B,C only these axes available but i want to offset U and V axes as well.
    I tried using G92 Uxxx. But this is not working.
    Please help me out with this problem.
    Regards
    Amit Kumar
    May 2006
    4045
    Re: How to get and set offsets for U and V axes
    Hi Amit,
    It seems to work for me.
    I tested with U axis resolution 100 counts per inch and U axis = KFLOP axis #6
    Executing this GCode:
    G20 (inch mode)
    G92.1 (Clear G92 offsets)
    G0U2 (Move to machine 2 inch)
    G92U0 (Set G92 offset to make this the origin)
    G0U1 (Move to 1 inch using this origin - actual machine position is 3 inches)
    M30
    Then KFLOP shows this (#6 Destination = 300 = machine position 3 inches)
    Attachment 406034
    TK
    http://dynomotion.com
  1. Fauna 21T tool offsets and work offsets
    By tar356 in forum Fanuc
    Last Post: 09-22-2017, 12:44 PM
  2. Need help - two slave axes of two main axes?
    By georgem in forum Mach Software (ArtSoft software)
    Last Post: 11-17-2015, 03:04 AM
  3. Replies: 2
    Last Post: 10-24-2014, 04:17 PM
  4. Help understanding work offsets and extended work offsets
    By tomvoutsas in forum Tormach Personal CNC Mill
    Last Post: 09-20-2013, 06:35 AM
  5. 4 Axes
    By GOBUS in forum DIY CNC Router Table Machines
    Last Post: 12-07-2005, 02:29 PM
