586,075 active members*
3,704 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Is there a Mach3 configuration file to save as back up.
Results 1 to 2 of 2
    Oct 2018
    10
    I just purchased a 5x10' Chinese CNC router with Mach 3 on an old PC as a controller. Is there a way to save all the current configuration settings in a single file in case the computer crashes? (or I want to change to another computer etc.) I don't want to be stuck setting it up from scratch. Any input appreciated.
    35538
    Re: Is there a Mach3 configuration file to save as back up.
    Just zip the entire Mach3 folder.
    The .xml file has all of the settings, but if you are using any custom macros, brains, or screens, you'll need those too.
