586,068 active members*
4,307 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Z AXIS NOT RESPONDING TO GCODE COMMANDS
    Dec 2017
    47
    Using GRBL controller, everything works right when I send my files except the z axis, it simply does not respond, Manual commands work perfectly as well the axis controls by
    keyboard. I am attaching the beginning of a file, maybe someone can see something I don't, thanx
    G00 G90 G17 G21
    M3 S24000
    (Contour 0)
    T1 M6
    X-70.877 Y110.684
    G01 Z-2. F150
    X-70.842 F450
    The x and y command responds, the z command does not.
    Apr 2014
    215
    Quote Originally Posted by bjwx2 View Post
    G00 G90 G17 G21
    M3 S24000
    (Contour 0)
    T1 M6
    X-70.877 Y110.684
    G01 Z-2. F150
    X-70.842 F450
    Is the z axis setup for the right pins and ports (check)
    Is the drive working (check, swap with a working axis.... This will also test the stepper motor)
    Dec 2017
    47
    Re: Z AXIS NOT RESPONDING TO GCODE COMMANDS
    Z axis works fine with manual control on keyboard and if I send a typed command in GRBL controller, does not respond to commands generated with artcam or abviewer? Just can't figure it out!
    Aug 2009
    56
    Any change if:
    (rapid movement)
    X-70.877 Y110.684
    Z-2. F150
    X-70.842 F450
    OR
    G00 X-70.877 Y110.684
    G01 Z-2. F150
    G01 X-70.842 F450
    Remove everything else in this code, just run those lines.
    Sep 2020
    hey
    not sure if you're still on this, since its been a while.
    but any chance you found a solution to this problem as I cant get my head around it
  1. Z AXIS NOT RESPONDING TO GCODE COMMANDS
    By bjwx2 in forum Uncategorised CAM Discussion
    Last Post: 11-15-2018, 06:26 PM
  2. Are there any commands to write a .txt/.tap file from a Gcode?
    By FuriousGeorge in forum Tormach PathPilot™
    Last Post: 08-16-2015, 01:22 AM
  3. U and V axis commands in Gcode.
    By AzzA2032 in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-04-2014, 07:42 AM
  4. Simple GCode Reference / Commands?
    By WarrenW in forum G-Code Programing
    Last Post: 11-30-2010, 10:03 AM
  5. Gcode commands for Plasmacam
    By jeffery71 in forum PlasmaCam
    Last Post: 11-01-2010, 02:50 PM
