586,089 active members*
3,862 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Optimizing GCode for faster curve cutting?
Results 1 to 12 of 12
    Dec 2017
    47
    Question Optimizing GCode for faster curve cutting?
    Is there any program to optimize cutting curves in gcode, thereby speeding up the cutting process?
    Feb 2011
    353
    Re: Optimizing GCode for faster curve cutting?
    you will have to give more information
    are you using a cam software and what is it ?
    someone maybe able to help if it the software is known
    Dec 2017
    47
    I am using Artcam and ABviewer to generate my files that I produce in Coreldraw, thanx.
    Nov 2018
    6
    you can use notepad and do a replace all of a specific feed rate if your not using CAM.
    Apr 2014
    215
    How do you cut a curve "faster"
    feedrate is a function of spindle speed, tooth load and the number of teeth on the tool?
    Spindle speed is a function of cutter diameter and surface speed (material specific).
    change the material, cutter diameter, number of teeth on the cutter (cutter material) and the feedrate can be changed to another optimum higher feedrate.
    _________________________________-
    Are you operating in constant velocity mode or exact stop?
    Sometimes in constant velocity mode if you have a lot of line segments the cnc machine will change the feedrate between the line segments (it is to do with centripetal acceleration )
    Suggest posting a section of your code and suggest what you want it to do?
    Are you doing roughing and finishing cuts? (that could improve your cut times).
    I don't think that there is enough explanation of what you perceive as "optimize" , you could use a different tool material / tool diameter and number of cutting teeth and it will all speed up the cutting process.
    The gcode is mainly linear and angular distance..... distance / speed = time....
    Jun 2015
    4154
    hello robertspark, please, will you share more details about this ? kindly
    Apr 2014
    215
    Have a look at example 1 here (car going around a corner), click on expand the solution.
    https://www.khanacademy.org/science/...l-acceleration
    Motion controller software has to work out how to join each line together and what the allowable centripetal acceleration is between each line segment. It does not need to do this with an arc..... it only has to consider the start and end of the arc and its junction with the next entity and the centriperal acceleration whilst motion is being done during the arc.
    It is easier to consider with something such as small lines and arcs.
    Say you draw an arc on a piece of paper 4" (100mm in diameter), and 270 degrees of arc.
    Now draw two lines off that same are at the start of the arc and the end of the arc.
    Now draw a curve fit arrangement of straight lines to try to follow the arc with straight lines...... pick a number say 10 lines arranged in the arc.
    At each junction the motion controller will need to adjust the junction feedrate relative to any limiting parameter for how closely you wish to follow the junction.
    (I use UCCNC and they can this setting "corner error max") It basically tells the motion controller how close you wish to follow the junction of 2 lines.
    I can try to explain better later if you need I've got to do something else.
    Dec 2017
    47
    I understand the arc segment principal, just wondered if there is a program to optimize the arcs for faster cutting, thanx
    What controller are you using? It's more likely the controller is the issue, not the g-code.
    Apr 2014
    215
    Quote Originally Posted by bjwx2 View Post
    No, an arc is an arc.
    It goes from X1Y1 to X2 Y2 with a radius
    As I asked below what do you see as OPTIMIZE?
    Use a bigger tool with more flutes with a more powerful spindle...
    Jun 2015
    4154
    please, go on a spree, i am all ears thank you
    I guess the job must do at CNC level enabling smooth movement with G64 P Q parameters.
    If your controller has smooting algoritms like bezier and Q parameters to define minimum coord tollerance you can improve movement and keep programmed feed.
    Is necessary to know what CNC you are unsing !
  1. Faster cutting, lower cost waterjet
    By nextwaterjet in forum Waterjet General Topics
    Last Post: 10-16-2018, 09:47 PM
  2. faster feed rate = more gcode lines??
    By a3dcreator in forum G-Code Programing
    Last Post: 01-26-2017, 02:43 AM
  3. Replies: 6
    Last Post: 11-23-2012, 03:29 AM
  4. How can I make tool cutting faster
    By Spencer myers in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-01-2011, 09:26 PM
  5. Will a solid carbide bit cut faster that a straight cutting bit?
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-11-2006, 01:10 PM
