Effective extra long end mill foam milling cutter tool bits for CNC router robotics
Nowadays 5-axis foam mill CNC routers, big gantry router for foam milling, 6 axis robotic arm, 7 axis industrial robots, are ideal for milling epoxy, foam and clay 3D design models.
But problems comes, as a lot of visitors leave message in the forums, under the Youtube videos where to get a effective router bits for EPS, Poly foam.
Long endmills, extra long router bits, longer milling cutter, DeepReach mills, BIG router bits are needed, but not easy to found a good router bits supplier who offers long milling cutters for foam processing.
RicoCNC specifically designed for milling Poly foam, Styrofoam, EPS, EVA, etc.
RicoCNC foam mill bits are widely worked with KUKA, YASKAWA robotics, gantry 5 axis machining centers, big foam-cutting gantry routers, and get great feedback and more orders from our clients.
If you are looking for effective eps and foams cnc milling extra long end mill cutters, welcome your inquiry.
