586,485 active members*
2,498 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > haas TM-2 2005 G83 feed issue
    Mar 2008
    9
    Hey guys.
    I have a 2005 Tm-2, and have an issue I was hoping one of you may have some insight on. All of the sudden when I perform a 83 peck drill all of the retracting motion is in feed instead of rapid. I recently used a program from someone else's cam software . Not sure if the coding used may have set up some type of modal issue that I am unaware of . I pretty much have been scratching my head on this one and hoping for some help.
    Thanx in advance.
    Dave
    Nov 2006
    490
    Re: haas TM-2 2005 G83 feed issue
    I can't speak to that specific problem, but I will say that I've indeed seen some CAM programs that output their own special type of peck cycle which consists of G0 and G1 movements moving up and down, rather than G83 / G73. I'd definitely check the code to see if there's like 20 lines for that one hole, rather than a single drill cycle
    Mar 2010
    1852
    If it actually says "G83," it is not in some strange code, that is a regular G83 cycle. Please post the code for us to see.
  1. Non Haas bar feed interface to Haas NexGen
    By BarfeedTech in forum Haas Lathes
    Last Post: 04-20-2018, 10:27 PM
  2. SFU 2005 BF12 BK12 SFU 2005 BF15 BK15 Spacing Question
    By millingTime in forum DIY CNC Router Table Machines
    Last Post: 10-19-2015, 03:49 PM
  3. Drip feed issue
    By Krefte in forum Controller & Computer Solutions
    Last Post: 05-20-2013, 03:39 PM
  4. Haas sl20 2005
    By ashro in forum Haas Lathes
    Last Post: 03-11-2010, 05:32 PM
  5. HAAS 2005 VF4SS for sale
    By CuttingEdgemfg in forum Haas Mills
    Last Post: 10-02-2008, 01:47 PM
