586,075 active members*
3,982 visitors online*
Results 1 to 8 of 8
    Nov 2017
    16
    alternative to bCNC
    Hello,
    I started with bCNC, but it's really buggy
    can someone point me to an easy to use soft to mill pcb's
    thanks
    May 2015
    1422
    Re: alternative to bCNC
    flatcam's pretty good for converting gerbers into gcode.
    Nov 2017
    16
    Quote Originally Posted by dharmic View Post
    ok but does it RUN the cnc ?
    May 2015
    1422
    Ah, sorry, missed that bit. It does not.
    Flatcam to create the gcode and Mach3 to run it, maybe?
    Apr 2005
    304
    What is buggy in bCNC?
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Nov 2017
    16
    I scan the surface, then I start the cnc process, the bit breaks off all the time (just the tiniest bit of it)
    so I rescan, reengrave, but loose in precision and top/bottom layer never prints the same depth
    so far I ruined tons of copper, money and patience with bCNC
    I use 20° 0.1mm bits
    Apr 2005
    304
    Are you using correct procedure for autoleveling?
    check this: https://github.com/vlachoudis/bCNC/wiki/AutoLevel
    Nov 2017
    16
    Quote Originally Posted by ZASto View Post
    thanks I'll check it out
    I lowered the feed rate in the mean time, seems to help a bit
  1. bcnc n motor control
    By Gregted in forum EZ-CAM Solutions
    Last Post: 05-19-2018, 03:40 AM
  2. PCB designer options for bCNC (Arduino UNO with GRBL)
    By asasergio in forum OpenSource Software
    Last Post: 11-03-2016, 07:00 PM
  3. Newbie could use some pointers/direction with Bcnc software
    By pitzerwm in forum Mentors & Apprentice Locator
    Last Post: 09-10-2016, 06:29 AM
