Hello,
I started with bCNC, but it's really buggy
can someone point me to an easy to use soft to mill pcb's
thanks
Hello,
thanks
flatcam's pretty good for converting gerbers into gcode.
Ah, sorry, missed that bit. It does not.
Flatcam to create the gcode and Mach3 to run it, maybe?
What is buggy in bCNC?
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
I scan the surface, then I start the cnc process, the bit breaks off all the time (just the tiniest bit of it)
so I rescan, reengrave, but loose in precision and top/bottom layer never prints the same depth
so far I ruined tons of copper, money and patience with bCNC
I use 20° 0.1mm bits
Are you using correct procedure for autoleveling?
check this: https://github.com/vlachoudis/bCNC/wiki/AutoLevel
