586,105 active members*
3,301 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Computer performance?
    Aug 2006
    133
    Currently I use Bobcad V27 and run it on a notebook computer with 2.8Ghz processor and 8 GB of RAM. The computer is about 5 years old and is used both in the shop and personal. It has taken a beating but still works good. I do have issues when trying to do 3D work with BobCad. The processor seizes up and often just flat out crashes and I lose all my unsaved work. I'm considering upgrading to a new computer with all the current sales underway in hopes of fixing these crash issues. For BobCad specifically, what performance criteria should I look for. I'm not a computer guy, so please keep the comments in simplistic terms. Appreciate any advice you can share.
    Dec 2008
    4548
    Quote Originally Posted by becikeja View Post
    Try turning the performance requirements in BobCad down.
    The surface and curve meshing angle sliders in display, current and default settings.
    Under view, you can also turn off anti aliasing and a couple others. If you want to go v21 hard core, you can turn off polygon shading and work in wireframe mode!
    Oct 2012
    22
    Re: Computer performance?
    becikeja
    Just get pentium 4 desktop and it will run fine. Laptops and notebooks are a no go.
    The v31 simulation does use alot of power and locks up if you have several other programs working.
    Splurge 30.00 for a g-force card and it will work even better.
    Cheers
    jc
  1. File transfering from design computer to Mach3 computer
    By Blisswoodshop in forum Avid CNC
    Last Post: 04-13-2017, 09:16 PM
  2. Replies: 8
    Last Post: 08-20-2014, 07:16 AM
  3. ArtCAM Computer Performance WORKSTATION VS END-USER PC
    By Lafaso870 in forum Jewelry Design Software
    Last Post: 11-12-2010, 09:36 AM
  4. Computer performance in a cold shop?
    By jsheerin in forum DIY CNC Router Table Machines
    Last Post: 03-11-2010, 06:37 AM
  5. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
