586,717 active members*
3,107 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > Manual book and hydraulic diagram Amada Shearing H-3013
Results 1 to 9 of 9
    May 2015
    16
    Hi everyone..
    I need manual book and hydraulic diagram Amada shearing H-3013.
    Please share..
    Your help very appreciated..
    Regards..
    Oct 2008
    27
    Re: Manual book and hydraulic diagram Amada Shearing H-3013
    Operator's manual, what is the production date of the machine?
    Attached Files Attached Files
    May 2015
    16
    Dear Hemikiller,
    Thank you for your reply..
    Production date November1996, see below photo..
    regards..
    Oct 2008
    27
    Here's the hydraulic diagram for the late machines
    May 2015
    16
    Hi Hemikiller..
    Thank you for your help..
    My Machine Amada shearing H-3013 the hydraulic oil temperature is very hot/high (we can't touch the cylinder and the pipe because it's very hot).. i'm still checking what caused the problem..
    As I checked on the manual for the hydraulic oil supposed to use Shell tellus 27 but currently I used shell tellus 46.. Do you think the problem because of this??
    Or setting pressure on the hydraulic valve (RV, PRV and URV) not properly??
    Regards..
    Mar 2009
    101
    1st off you need to run the correct oil. Amada techs dont put in various oils and record what happens. 2nd I would check your accumulator pressure. When ram reaches bottom of stroke do you hear a loud bang? That means safety valve is kicking in. Low on nitrogen. #3 They do run pretty hot, maybe you never noticed before.
    Best regards,
    May 2015
    16
    Dear Amadajoe,
    Thank you for your feedback..
    Last time I check accumulator pressure +- 60 bar, bigger than standard on the manual (around 30 bar )
    And how to setting RV, PRV, and URV valve? Currently I check the machine it's fully adjusted/not properly adjusted.
    Because i think this machine also have problem low pressure..
    Regards,.
    Mar 2009
    101
    Why are you overcharged on your accumulator? If you are @ 60 bar and manual says 30. You need to drop it big time. I have never had any reason to adjust valves. If you are going to move valves, measure thread with a caliper so you can set back to original condition.
    Quote Originally Posted by Hemikiller View Post
    C?m ?n b?n
  1. Takisawa TC-2 CNC lathe, need manual book, electric book, fanuc manual
    By godzila in forum Machinery Manuals / Brochures
    Last Post: 07-20-2021, 05:43 AM
  2. Amada Vipros 357 Hydraulic Top Dead Center Issues
    By Luftegrof in forum DNC Problems and Solutions
    Last Post: 02-14-2017, 05:35 PM
  3. AMADA NC9 need some wire diagram or manual
    By Suxo in forum DNC Problems and Solutions
    Last Post: 05-14-2016, 11:48 PM
  4. Connection Diagram AMADA Fanuc
    By CNC Business in forum Want To Buy...Need help!
    Last Post: 02-06-2013, 05:31 AM
  5. QC12Y-8x600 shearing machine digram manual
    By cyruss07 in forum Machinery Manuals / Brochures
    Last Post: 12-13-2012, 07:28 AM
