586,116 active members*
3,469 visitors online*
    Jan 2007
    122
    Spindle Fuse?
    Well I was facing off a part and stalled out the spindle, now I have zero power to the spindle rpm display and all spindle controlls. Is there a fuse or a breaker to reset?
    X2? X3?
    On my X2, there is a current limit in the motor circuit. The spindle will shut down and the yellow light will go on. Turn the motor off and then on again to get it working.
    I had to adjust the current limit (torque) potentiometer to stop this from happening as much.
    -Jeff
    www.JeffAlbro.net/cnc/
    Jan 2007
    122
    Well thats not it, i have the feeling that it triped my E Stop button and it wont reset.
    Jul 2005
    13
    The same thing just happened to me with my X3. Did you pull off the cover at the back? If not pull it off and look at your spindle board. The ribbon from the board to the spindle was cooked on mine. Had to call Syil. (1-888-594-1097) They sent me a new board, ribbon and transformer. I 'm putting it back together this weekend. My fuse looked fine. I'm in Canada so I was down for about a week waiting for the replacement. Good luck.
  1. Fuse Selection
    By Cooper in forum CNC Machine Related Electronics
    Last Post: 01-16-2007, 08:33 PM
  2. Where can I get fuse
    By motomitch1 in forum Fanuc
    Last Post: 06-25-2006, 01:38 AM
  3. Another Fuse Question?
    By drakesis in forum CNC Machine Related Electronics
    Last Post: 06-15-2005, 03:02 PM
  4. G-201 fuse
    By Dylwad in forum Gecko Drives
    Last Post: 01-19-2005, 02:30 PM
  5. Where to find a fuse
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 10-27-2004, 02:29 AM
