586,033 active members*
3,481 visitors online*
    May 2017
    82
    Updated drawing
    Updated the drawing I submitted that was put on the Wiki site.
    Updated drawing includes grounding of shields for limit switches, grounding of spindle and VFD, energy dump circuit, removed erroneous grounds to chassis I wired originally and includes a forth axis to use either a Stepper motor or Servo motor. All has been tested except the servo motor circuit for a forth axis, I have not built the 4th axis yet and have not decided if I will use a stepper or servo, I am leaning towards a servo for the higher torque at higher speeds.
    I hope the intermittent G code error is now fixed with removing the erroneous chassis grounds I wired.
    Please remove my original drawing from the Wiki site and if you want post the new one.
    Joe
    May 2006
    4045
    Re: Updated drawing
    Hi Joe,
    Updated.
    Thank you
    TK
    http://dynomotion.com
  1. Replies: 1
    Last Post: 04-02-2016, 12:56 AM
  2. new drawing board --wicked size 44x60 drawing area
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 02-08-2015, 12:58 AM
  3. where to get SC updated?
    By eeenhy in forum SprutCAM
    Last Post: 07-01-2010, 05:54 PM
  4. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  5. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
