586,655 active members*
3,350 visitors online*
Results 1 to 10 of 10
    Jan 2014
    32
    Tool Release Piston - Shims
    I picked up a 2005 HAAS VF2SS over the weekend and set it up.
    I wasn't able to get the spindle to take a tool. The draw bar wasn't coming down far enough. I ended up following HAAS 30/40 Taper - Tool Release Piston - Sensor Adjustment - VMC and needed to add .05" shims. I can get a tool holder in the spindle now and everything seems fine.
    As far as I know, there were no issues prior to transporting the machine. It did sit unused for a few months.
    Curious if anyone has came across this, or if there is something else I should be concerned about or looking for other than shimming the striker plate?
    Jun 2004
    6618
    Re: Tool Release Piston - Shims
    A good temperature change is probably enough to cause this.
    Lee
    Jan 2014
    32
    I am in Minnesota and the machine traveled in 32 degree weather for 4 hours, would it be in my best interest to give it a week or so to warm up and re check everything?
    Jun 2004
    6618
    That I can't tell you. I would say if it works with a shim when cold, it may still be in tolerance when it warms up.
    It could have been borderline tolerance before and freezing it changed that.
    Lee
    Jun 2003
    1365
    Does it sound like the solenoids are running properly?
    Jun 2004
    6618
    One issue with used machines is that you do not really know how dry the air was that was used in it.
    Poor quality air can stifle and kill parts over time.
    Lee
    Jan 2014
    32
    Yes, solenoids sound like they are functioning properly. Any way to test to verify? Somebody did mention possibly moisture in solenoid from traveling and temp change?
    Dec 2013
    15
    Did you check the drawbar?
    Make sure you set the clamp/unclamp switches after you added shims.
    Run it for a week and then check TRP Height to make sure it’s still the same .
    15362
    Quote Originally Posted by bthomas7408 View Post
    The only way you will get water / condensate in the valves would be through your air lines, which you need to check to make sure your air is dry this would not change the stroke of the draw bar though even if there was water or condensate in them
    I would say that it is most likely over due for a Drawbar maintenance, it could also have a broken Belleville washer, even if it is just a clean up and new moly grease added it would be worth while, they are not hard to do
    Mactec54
    Nov 2012
    145
    When we got our TM1P we had a 1/2” cutter that wouldn’t fit into the 1/2” holder till it warmed up.
  1. Replies: 7
    Last Post: 08-14-2020, 02:13 PM
  2. Bad crash: Tool won't release, flashing release button
    By CrashTestDummy3 in forum Daewoo/Doosan
    Last Post: 04-04-2018, 02:38 PM
  3. Tool release??
    By Trent-cnc in forum Fanuc
    Last Post: 03-12-2012, 10:36 AM
  4. Tool Release Piston Failure?
    By JoBwan in forum Haas Mills
    Last Post: 07-30-2009, 11:35 AM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
