Re: I'm stuck as to what I use as a base to clamp the job in the machine?
I use 2 sheets of MDF, the top sheet is a spoil board that can be resurfaced as needed.
The spoil board has a pattern of flanged E-Z LOKS installed from the bottom side. The downside to this set-up is the limited number
of times the spoil board can be resurfaced. Alternately the e-z locks could be installed in the bottom sheet of MDF.
Link --> https://www.ezlok.com/e-z-hex-thread...-for-soft-wood
For clamps I use these most often
Link --> https://www.thingiverse.com/thing:776
The fastening is done with assorted 1/4-20 bolts instead of that knob thing. Spit dowel to fit the top notches provides sure clamping.
My work is mostly sheet goods.
