586,106 active members*
3,048 visitors online*
    Apr 2007
    17
    Running Stepper Motors
    I am having problems with one of my motors. I toggle the motor in a positive direction at different intervals. The motor will turn the correct direction during the first few intervals and then the motor will start going the other direction for an interval. I am using Mach3 and in the process of learning this program and setting up the CNC machine. My other two motors are running fine. Is there a problem with the motor or a Mach3 setting??Is there a Mach3 forum?
    Apr 2007
    17
    Im using stepper motors.
    Feb 2007
    498
    i would check the step/direction wires,make sure they are not backwards
    if the other two motors work fine,check the setttings for them see if something is different on the problem one,maybe a setting is wrong,just a place to start
    Feb 2007
    498
    i will bet it the step and direction wires are backwards
  1. Unsure About Running Stepper Motors
    By tmd019 in forum Hobbycnc (Products)
    Last Post: 04-22-2007, 06:28 PM
  2. Stepper running choppy
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 02-15-2007, 03:36 AM
  3. running stepper at 12v
    By mikejkd in forum Stepper Motors / Drives
    Last Post: 05-24-2005, 07:42 PM
  4. Running 2 motors on the same axis
    By xairflyer in forum Stepper Motors / Drives
    Last Post: 03-07-2005, 01:31 PM
