586,105 active members*
3,248 visitors online*
    Apr 2007
    17
    Problems with my stepper motor
    I am having problems with one of my motors. I toggle the motor in a positive direction at different intervals. The motor will turn the correct direction during the first few intervals and then the motor will start going the other direction for an interval. I am using Mach3 and in the process of learning this program and setting up the CNC machine. My other two motors are running fine. Is there a problem with the motor or a Mach3 setting??
    Apr 2007
    60
    Could you swap two of your motors and see if the problem stays with the suspect motor ?
  1. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  2. Motor problems
    By johnm99 in forum Stepper Motors / Drives
    Last Post: 03-03-2006, 09:11 PM
  3. Help with Stepper Problems
    By ckrantz in forum Stepper Motors / Drives
    Last Post: 01-01-2006, 06:08 AM
  4. Motor Problems
    By MikeAber in forum Charter Oak Automation Support Forum
    Last Post: 12-13-2005, 06:22 PM
  5. Stepper motor torque problems?
    By Chris D in forum Stepper Motors / Drives
    Last Post: 06-07-2005, 07:15 PM
