586,115 active members*
3,380 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > How to enable ethernet and set IP Address on SL-204 with MAPPS MSG-805
    According to the "Caps-Server Instruction Manual" (WIN-CAPSSERVER-A0E) which states it's applicable with the MSG-805, there should be a soft key option called "COM SET" for setting the IP Address.
    Our other Mori Seiki CNCs did have this option, but for some reason this machine doesn't have it.
    Is there another parameter somewhere that needs to be changed to enable the ethernet menu?
    Thanks.
    Jun 2016
    Re: How to enable ethernet and set IP Address on SL-204 with MAPPS MSG-805
    HI,
    I have the same problem on the same machine. Is there anyone who knows the solution, which parameter enables the network option?
    We have checked, and we have the Ethernet port...
    Regards.
  1. Mori Mapps IF ethernet/IP messaging
    By jeremydgrossman in forum Mori Seiki Software
    Last Post: 09-28-2019, 01:35 PM
  2. Smoothstepper ethernet or Xhc Mk4-v 4axis ethernet?
    By Nleo22 in forum Want To Buy...Need help!
    Last Post: 09-08-2017, 11:37 PM
  3. MAPPS
    By littlerob in forum Mori Seiki lathes
    Last Post: 09-30-2009, 02:52 AM
  4. MAPPS CNC
    By sjh in forum Controller & Computer Solutions
    Last Post: 04-20-2009, 11:44 AM
