Look into www.mcmaster.com and look at their timing belt/pulleys, .2 pitch works, at least 1:2.5 reduction or higher, i.e. a 10 tooth on the motor shaft, and a 25 tooth on the driven shaft. I would go higher if you can find the pulley, say a 50 tooth pulley for a 1:5 ratio.
Chain and sprockets could also be used, or planetary gearboxes, if you can find them cheap enough.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
