586,103 active members*
3,296 visitors online*
Results 1 to 15 of 15
    May 2009
    9
    Using variable
    When I try using the variable listed in the reference document, most of them so not seem to work.
    When I add this code to the Init Tool Change section
    :T:<N><TOOL_COMMENT><EOL>
    :T:<TOOL_DIAMETER><EOL>
    :T:<TOOL_DESCRIPTION><EOL>
    The output generated is
    (M4.0 X 0.7 TAP)
    <TOOL_DIAMETER>
    <TOOL_DESCRIPTION>
    Only the TOOL_COMMENT seems to work. Do you have to add additional code toe the LIB files to activate these variables?
    Is there a variable I can use to extract the current Setup name and Operation name?
    Jun 2006
    48
    Re: Using variable
    Quote Originally Posted by slammers View Post
    TLP_OPER_NAME (check UPG Help - Complete Reference Guide)
    I'm also heaving problem to output STOCK_LENGTH, STOCK_WIDTH and STOCK_HEIGHT... Is that somehow related with SolidworksCAM, so not all variables are available if you don't have CAMworks?
    Feb 2010
    69
    Re: Using variable
    Try thes syntaxes
    <"#3.3T":STOCK_LENGTH>
    <"#3.3T":STOCK_WIDTH>
    <"#3.3T":STOCK_HEIGHT>
    <"#3.4":TOOL_DIAMETER>
    For tool description, I never try it
    You can try add this to your mill.lib file
    :ATTRNAME=TOOL DESCRIPTION
    :ATTRTYPE=POST
    :ATTREMARK=
    :CODETYPE=FORMAT
    :WORD_ADDRESS_BEF=|(
    :VAR=TOOL DESCRIPTION
    :WORD_ADDRESS_AFT=)
    :LEFT_PLACES=0
    :RIGHT_PLACES=0
    :UNITFLAG=NON_CONVERT
    :ATTRSPACES=YES
    :MODAL=NO
    :ATTRUSED=1
    :ATTREND
    Jun 2006
    48
    Re: Using variable
    Quote Originally Posted by vincent.pomerleau View Post
    Try thes syntaxes
    This actually works! Thank you!
    Next thing I'm struggling with is how to modify G40/G41/G42 output in the way that G40 would be replaced with C0, G41 with C1 and G42 with C2. (It's an Italian SCM woodwork router and it taks a bit odd code).
    Feb 2010
    69
    Re: Using variable
    Try replacing these sections in .src file
    :SECTION=LINE_LEADIN_MOVE_MILL
    :T:C<%COMP-40)><G:1><X!><Y!><Z><F><EOL>
    :SECTION=LINE_LEADOUT_MOVE_MILL
    :T:C0<G:1><X!><Y!><Z><F><EOL>
    Feb 2010
    69
    Re: Using variable
    Replace by : (
    Jun 2006
    48
    Re: Using variable
    Replace by : (
    I figured it out
    Is there a way to change G00 to G0 and G01 to G1 and G02/G03 to G2/G3 ? That zero machine doesnt like at all...
    Feb 2010
    69
    Re: Using variable
    at the start of .src file change these
    LEADING=FALSE
    INT_LEADING=FALSE
    Jun 2006
    48
    Re: Using variable
    LEADING=FALSE
    INT_LEADING=FALSE
    Thank you for replay, I solved it in this way, for example arc moves: G <"%1LT":ARC_DIR> and as far as I testedd it it looks OK.
    Next thing I need to change is "inverting" axis Y and Z, as on machine Z positive is downwards that means Y is "rotated" arround X. This means that my WCS (work coordinate system) is always placed on top-left corner.
    Feb 2010
    69
    Re: Using variable
    Copy this to you .lib file, it should work, you may have to reverse your arc direction to make this works,register are x=24 y=25 z=26
    :SECTION=CALC_ENDPOINT(DVAL,DEFAULTVAL,GC,GG,G_GRO UP,MACH,PREV,REGISTER)
    :C: IF ATTROVERRIDE=YES THEN DVAL=ATTRDVALUE ELSE DVAL=DEFAULTVAL ENDIF
    :C: PREV(REGISTER)=MACH(REGISTER)
    :C: IF abs_inc=1 THEN MACH(REGISTER)=(DVAL) GOTO1 ENDIF
    :C: BUCKET=0
    :C: ROUNDOFF(DVAL-MACH(REGISTER),BUCKET,DVAL,G_RIGHT_PLACES,METRIC_O UT)
    :C: SETON()
    :C: IF ABS(DVAL)<ROUNDING_POINT AND LEADIN=NO AND
    :C: LEADOUT=NO THEN
    :C: SETOFF()
    :C: ENDIF
    :C: MACH(REGISTER)=(MACH(REGISTER)+DVAL)
    :C1: IF REGISTER=24 THEN RETURN ENDIF
    * FLIP SECTION
    :C: DVAL=(-DVAL)
    this section may have to be modified too, register are I=9 J=10 K=11
    :SECTION=CALC_CENTER(DVAL,DEFAULTVAL,GC,GG,G_GROUP ,MACH,PREV,P_REG,REGISTER,AIC)
    :C: IF ATTROVERRIDE=YES THEN DVAL=ATTRDVALUE ENDIF
    :C: IF ATTROVERRIDE=NO THEN DVAL=(DEFAULTVAL-PREV(P_REG)) ENDIF
    :C: IF REGISTER=10 OR REGISTER=11 THEN RETURN ENDIF
    :C: IF REGISTER=9 THEN
    :C: IF working_plane<3 OR working_plane=5 THEN RETURN ENDIF
    :C: ENDIF
    * FLIP SECTION
    :C: DVAL=(PREV(P_REG)-DEFAULTVAL)
    and this one too to reverse the Z in drilling cycles
    :SECTION=CALC_DEC_REGISTER(DVAL,MACH,DEFAULTVAL,RE GISTER)
    :C: MACH(REGISTER)=DVAL
    * FLIP SECTION
    :C: DVAL=(-DVAL)
    Feb 2017
    11
    Re: Using variable
    Vicent
    Give me tis error
    "Error Primary var: G not foundMETRIC_O UT) SETON() IF ABS(DVAL)<ROUNDING_POINT AND LEADIN=NO AND LEADOUT=NO THEN SETOFF() ENDIF MACH(REGISTER)=(MACH(REGISTER)+DVAL):C1
    error 1 at 216 in CALC_ENDPOINT
    Syntax error or unrecognized variable name
    lane<3
    error 1 at 187 in CALC_CENTER
    Syntax error or unrecognized variable name"
    Feb 2010
    69
    Re: Using variable
    Hi
    For the first error remove de space from
    METRIC_O UT) -----> METRIC_OUT)
    For second error, my post is build to handle angle head for horizontal work, I have the working_plane variable to handle this, in your case you will have to create your own condition, if you want to always flip it, just remove this line
    Feb 2017
    11
    Re: Using variable
    Help me
    Attached Files Attached Files
    Feb 2010
    69
    Re: Using variable
    What are you trying to do or what is the problem ?
    Feb 2017
    11
    Re: Using variable
    Hi i try invert axis Y and Z, and arcs J.
  1. Assigning post variable to Vbscript variable
    By vfsi in forum BobCad Post Processors
    Last Post: 10-18-2016, 01:30 PM
  2. pls, need some variable
    By deadlykitten in forum Okuma
    Last Post: 11-03-2015, 02:45 PM
  3. Variable zero
    By Dave Elliot in forum DNC Problems and Solutions
    Last Post: 05-28-2010, 10:38 AM
  4. Variable changes
    By TNorbut in forum Controller & Computer Solutions
    Last Post: 07-23-2008, 01:16 PM
  5. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
