586,106 active members*
3,021 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Phase perfect to 480v transformer help needed .
Results 1 to 17 of 17
Threaded View
    Oct 2011
    19
    I have a 30hp phase perfect that goes into a sub panel that feeds a haas vf2ssyt at 240v and it also feeds a 240-480v transformer that runs my haas st-10 lathe . when I have power going to the transformer the led lights in my vf2 will flicker a bit . if I turn on the st-10 the light will flicker in there too . not sure what is causing this . I checked the voltage between phases and all is good and I do not see any real fluctuation between phases . everything works fine on the lathe but the flickering light gets a bit annoying . here is a picture of the plate on the transformer .
  1. Torqcut 30 480v can it be run on 230v? and could it run on single phase?
    By A1CNC in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2016, 08:43 PM
  2. Replies: 8
    Last Post: 07-11-2013, 09:39 PM
  3. Problems with a 480V three phase rotary air compressor
    By Eric MFG in forum Maintenance DIY Discussion
    Last Post: 07-10-2012, 02:26 AM
  4. Replies: 3
    Last Post: 09-28-2007, 01:09 PM
  5. 3 phase transformer needed
    By pauluk in forum CNC Machine Related Electronics
    Last Post: 12-26-2005, 10:02 PM
