586,077 active members*
4,009 visitors online*
    Apr 2004
    36
    IH Breakout Board
    I have one of the first IH machines. Breakout board for servos fried. Apparently Bob Campbell who supplied the original boards is no longer active. Does anyone have a source for a replacement board?
    Mar 2007
    2083
    Re: IH Breakout Board
    which BOB do you have ?
    if you can post photos and a link to the data sheet
    I expect the closest alternative could be a BOB from the likes of CNC4PC
    and a couple of power supplies mounted on a chassis the size of Bob Campbell's BOB
    and made into a drop in replacement
    if you lived in the UK I could of looked at it to see if its repairable
    provided the PCB tracks and any programmed PIC or Atmel chip are OK
    John
    PS
    is it like this ?
    Attachment 406554
    PPS
    I am thinking of something like CNC4PC's C11S and separate power supplies
    http://cnc4pc.com/Tech_Docs/C11S-R1%202_USER_MANUAL.pdf
    if you need the 4th relay add a C37 relay
    Apr 2004
    36
    yes, its the same the first listed..thank you ill visit that site.
    paul
    Jun 2005
    1015
    i'd switch over to a smooth stepper and modern controls for mach 3. make sure you get an ethernet breakout board
  1. Help deciding which breakout board or driver board etc to use!
    By localbroadcast in forum Servo Motors / Drives
    Last Post: 06-09-2016, 09:25 PM
  2. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
  3. Breakout board with ESS
    By AchillesGr in forum CNC Machine Related Electronics
    Last Post: 01-11-2013, 09:59 PM
  4. Help: anyone know this breakout board?
    By fabribi in forum Open Source Controller Boards
    Last Post: 02-21-2010, 12:20 PM
  5. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
