586,052 active members*
4,253 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Spring Loaded Collet
    Shabalala Guest
    Does anyone know what the deal with this:
    https://www.youtube.com/watch?v=9DhPwtCZ9u4
    is? At 4:58, the operator put in a spring into the collet then tightens it. I'm not sure why tightening doesn't prevent any movement at all?
    Nov 2005
    222
    Re: Spring Loaded Collet
    I'd say it's because it's not really tight. He pushed the bit far enough in so that the set screw is on the flat. But not tight on it.
    Nov 2012
    1267
    The set screw is not tightened on the cutter, it just prevents the cutter from falling out.
    Shabalala Guest
    Understood! Thanks guys!
  1. Spring loaded pen plotter tool
    By Joe2014 in forum Uncategorised WoodWorking Machines
    Last Post: 03-01-2016, 07:36 PM
  2. Spring loaded rod problem...
    By nadsab in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-04-2011, 07:09 PM
  3. 14.77 Spring Loaded Engraver
    By fretsman in forum Engraving Machines
    Last Post: 04-29-2008, 01:21 AM
  4. Spring loaded graver drawing
    By fatal-exception in forum Engraving Machines
    Last Post: 04-21-2008, 01:24 AM
  5. THC Floating head needs to be spring loaded?
    By Normsthename in forum Waterjet General Topics
    Last Post: 12-12-2007, 02:44 PM
