586,121 active members*
3,031 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport cheap ballnut in the factory yoke
Results 1 to 3 of 3
    Apr 2018
    43
    I’m hobbyist and I need your support to convert a Brideport into a CNC milling at the lower cost possible.
    First, I have to remove the backlash. Can I remove the old factory screw and replace it with cheap china ballnut?
    Thanks,
    Jeff
    Dec 2013
    5717
    Re: Bridgeport cheap ballnut in the factory yoke
    You might have to replace the yoke to accommodate the diameter of the new nut. As I recall the housing for the original nut is a bit small for a ball nut.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2008
    Check out these guys. Very good people. https://www.machinerypartsdepot.com/
  1. Bridgeport ballscrew retrofit, design the yoke
    By daroc30 in forum Bridgeport / Hardinge Mills
    Last Post: 12-13-2022, 07:28 AM
  2. Bridgeport plasma on the cheap
    By Ubatoid in forum Videos
    Last Post: 12-11-2010, 06:32 PM
  3. Preloaded ballnut vs stock ballnut.
    By spaceballs_3000 in forum Benchtop Machines
    Last Post: 04-24-2008, 07:35 AM
  4. I Need a Yoke (and/or dims) for a Bridgeport
    By mxtras in forum Bridgeport / Hardinge Mills
    Last Post: 03-20-2006, 09:35 PM
