586,389 active members*
3,093 visitors online*
    Oct 2018
    4
    Platter on HRC210 vs HRT210
    All can anyone confirm if the same backplate can be used on a Haas HRC210 and a HRT210?
    The drawings look close by looking for some sort of confirmation
    Nov 2006
    490
    Re: Platter on HRC210 vs HRT210
    The platter's T-slot mounting points are the same. They don't look identical due to the internal differences (for instance the opposite side of the indexer is very different) but the same fixtures can be mounted on both.
  1. Platter on HRT160 vs HRT160SP
    By dave0173 in forum Haas Mills
    Last Post: 11-05-2018, 03:49 PM
  2. Advice for stable high speed rotory platter
    By drwho9437 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2012, 01:31 AM
  3. hrt210?
    By Brendan in forum Haas Mills
    Last Post: 08-09-2012, 02:41 AM
  4. Rotary platter/3-jaw chuck fitting.....
    By prtmkr2010 in forum Haas Mills
    Last Post: 07-22-2011, 01:47 AM
  5. HRT210
    By rrbmachining in forum Haas Mills
    Last Post: 02-05-2011, 02:57 PM
