586,069 active members*
3,737 visitors online*
Results 1 to 8 of 8
    Sep 2007
    37
    SIEMENS 828D RIGID TAPPING WITH IMPERIAL TAPS
    Hi All
    i currently have an issue with rigid tapping with an 8-32 unc tap , i am used to metric tapping but if i try and put a metric value to an imperial tap in the code the machine throws an alarm 61001 , which is telling me that it cant correlate the tap size with the pitch which in metric is 4.166mm x 0.794mm . Can anybody help please with the sample code
    Oct 2009
    42
    Re: SIEMENS 828D RIGID TAPPING WITH IMPERIAL TAPS
    Does your pitch/ lead match the tap in the tool library? Are you using shop mill or din-iso code? Attach your code if you could
    Sent from my SM-G965U using Tapatalk
    Sep 2007
    37
    ; %_N_0013_MPF
    ; T4 D=4.166 CR=0 - ZMIN=-12.7 - right hand tap
    G90 G94
    G71
    G64
    G17
    G0 SUPA Z0 D0
    M9
    T="8-32TAP"M6
    ; 8-32 UNC ROLL TAP
    S1000 M3
    G54
    X-430.679 Y-93.46
    D1
    Z10
    M8
    G17
    F794
    MCALL CYCLE84(10, 0, 2, -12.7, , , 3, 4.165, 0.794, 0, 1000, 1000)
    X-430.679 Y-93.46
    X-380.679
    X-404.321 Y93.46
    X-354.321
    X354.321
    X404.321
    X380.679 Y-93.46
    X430.679
    MCALL
    G1 Z10
    G0 SUPA Z0 D0
    M30
    Sep 2007
    37
    When i tap with metric taps i dont have any problems so not sure which part it doesnt like, attached is the code that works with metric taps
    ; %_N_0012_MPF
    ; T8 D=4 CR=0 - ZMIN=-10.795 - right hand tap
    G90 G94
    G71
    G64
    G17
    G0 SUPA Z0 D0
    M9
    T="4TAP"M6
    ; M4 X 0.7 TAP
    S1194 M3
    G54
    X-443.598 Y-211.435
    D1
    Z50
    M8
    G17
    F836
    MCALL CYCLE84(50, -3.175, 2, -10.795, , , 3, 4, 0.7, 0, 1194, 1194)
    X-443.598 Y-211.435
    Y-151.435
    Y-91.435
    X-341.402 Y91.435
    Y151.435
    Y211.435
    X341.402
    Y151.435
    Y91.435
    X443.598 Y-91.435
    Y-151.435
    Y-211.435
    MCALL
    G1 Z50
    G0 SUPA Z0 D0
    M30
    Oct 2009
    42
    I'll have to look at it tomorrow when I get to work. Also have you tried re-compiling the mcall cycle84 line? Basically you put your cursor on the same line and either arrow to the right or hit the re-compile button? Sometimes sinumerick will see issues with a parameter and highlight it in red. I'm assuming your using a cam system?
    Sep 2007
    37
    Thanks, yes i am using a cam system , HSMWorks , i might give it a try and preview the code in there
    Sep 2007
    37
    hey thanks for the heads up , that worked a treat, i pulled the program into the machine and did as you mentioned . Yaaay after half a day of muckin around hehe , dont know why i didnt think of that :banana:
    Oct 2009
    42
    No problem! I used that trick to help fine tune my post processor. If your having problems with a CYCLE call compare the parameters before you send it to the machine and after the control fixes any issues and have your CAM guy fix it.
  1. Recommended Taps for Rigid Tapping
    By Steve303 in forum Novakon
    Last Post: 09-08-2018, 07:52 PM
  2. breaking taps, rigid tapping 10-32 in SS-304/304L
    By Chriseg1 in forum Haas Mills
    Last Post: 11-16-2011, 12:11 AM
  3. Replies: 9
    Last Post: 09-09-2011, 11:57 AM
  4. TM-1 rigid tapping -which taps.
    By sensph in forum Haas Mills
    Last Post: 05-15-2009, 02:51 AM
  5. Feed & Speed for Imperial Taps
    By australia in forum Australia, New Zealand Club House
    Last Post: 12-08-2007, 06:55 AM
