586,052 active members*
3,935 visitors online*
    Oct 2009
    56
    DMG 50T TNC426/430 Error C3B0
    Hi All
    I have a Deckel Maho dmg 50t year 2000 running a Heidenhain TNC 426 control. On start up without trying to move any of the Axis the power on Y Axis goes high and I get a C3B0 Error.
    I have had a Heidenhain tech look at it who found there seemed to be current leakage to earth in the cables so I replaced these with genuine cables but the Error still comes up .
    I removed the Inverter and had it tested by the tech on his bench, it appears fine.
    Any help with this issue would be appreciated
    Regards
    Nick
    The more I learn, the more I find there is to learn
    Regards Nick
    Dec 2011
    99
    Re: DMG 50T TNC426/430 Error C3B0
    This is a very general error message
    Error description 2923
    Error message: C3B0 Motor ? does not rotate
    Cause of error
    - Inverter not ready
    - Disturbance on RDY input of the PWM output connector
    - Motor locked
    - Motor defective
    - Motor cable defective
    - Humidity has entered the motor
    - Inverter defective
    - Incorrect motor selected (MP2200.x).
    - Assignment of PWM outputs incorrectly entered in MP120.x
    - Assignment of encoder inputs incorrectly entered in MP112.x
    - Motor power cables mismatched
    - Motor encoder cables mismatched
    - Motor connection faulty
    Corrective action
    - Inform your service agency
    - Check the inverter
    - Check the motor and cabling
    - Check the machine parameters
    OR
    Error description 8103
    Cause of error
    - Motor jammed
    - Motor defective
    - PWM output incorrectly assigned
    - Speed encoder incorrectly assigned
    - Motor power cables crossed
    - Motor encoder cables crossed
    - Defective motor connection
    - I2t monitor has responded
    Corrective action
    - Check the motor for proper selection
    - Check the PWM-output parameters (MP 803, MP 1103)
    - Check rotary encoder input parameters (MP 803, MP 1103)
    - Check the I2t monitoring (MP 803/827, MP 1103/1113)
  1. Dmu50 evo with Tnc426/430
    By five7 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-05-2018, 07:42 AM
  2. HEDENHAIN tnc426 MP line without number error
    By Nil27 in forum Maintenance DIY Discussion
    Last Post: 11-05-2018, 05:06 PM
  3. tnc426 iso codes error in drilling taping reaming cycle
    By fsa in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-05-2018, 06:09 AM
  4. TNC426
    By pocio in forum Post Processor Files
    Last Post: 05-16-2014, 02:35 AM
  5. Error code C3B0 and 0380 on Hedeinhain DMC63V CNC Machine
    By remzy68 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-29-2009, 07:12 AM
