586,070 active members*
3,635 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > DMU50V Parameter for C axis rotation limit
    Apr 2017
    7
    HI!
    Is there parameter for C axis rotation limit for DMG DMU 50V millplus V400 year 97?
    When my c axis rotation table reach 9600 deg its approx 25 turns.
    It stop and give error C31 (rotation Limit).
    So is there machine parameter what i can fix or is it postprocessor issue?
    Please let me know!
    JR
    Jan 2016
    4
    Re: DMU50V Parameter for C axis rotation limit
    Hi.
    You can use G93 C3=1 for zero out your c axis (depending on how many degrees it stand, it will be between 0-360 deg).
    It wont change your work offset c value,
