587,076 active members*
3,092 visitors online*
Hybrid View
    Aug 2005
    177
    Milling side cut
    I am cutting 6061, 2.6 long side cut. Using 3. LOC steel titantium mill.
    I'm Taking .005 side cut, Mill chatters and anything over 900 rpm and I have to run 30IPM.
    The finish is constant but not smooth.
    How do you do a cut like this. What tool.
    Rob
    Dec 2013
    5714
    Re: Milling side cut
    Try making the cut by doing it in several passes, stepping down 0.500 on each pass. I have actually relieved the end mill above 0.5 inch so it only cuts with with that.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2005
    177
    I rough cut that way and leave .005 final wall thickness.
    Then the side needs final cut. In one pass to have perfect surface
    Dec 2013
    5714
    The problem seems to be that you are not getting a perfect surface by making a full depth cut.
    Here are a couple of pictures of a piece I did a while back. 1/2 inch 4 Flute, HSS endmill (from China), 0.020 left to finish, 0.25 DOC, continuous spiral down, don't remember the feed & speed, material = 4150
    And here is the finished surface, no step down lines, and smooth as a baby's bottom.
    Can't hurt anything to give it a try
    EDIT: Here is a gear case out of 6061, 2 inches deep, done the same way as above, same result. Just out of the dishwasher.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2005
    177
    I see. Great idea. I'll try it. Thanks much.
  1. Side Profile Milling
    By KrisCapeTown in forum EdgeCam
    Last Post: 02-19-2014, 09:53 AM
  2. Side Milling
    By eliot15 in forum GibbsCAM
    Last Post: 09-20-2011, 03:01 PM
  3. Side Milling....singing
    By behindpropeller in forum MetalWork Discussion
    Last Post: 12-03-2010, 02:34 AM
  4. Milling with bottom vs milling with side?
    By REVCAM_Bob in forum Community Club House
    Last Post: 06-30-2008, 03:23 PM
  5. Side Milling
    By SKEETO in forum MetalWork Discussion
    Last Post: 12-18-2007, 01:04 AM
