586,042 active members*
3,677 visitors online*
Results 1 to 6 of 6
    May 2016
    12
    Quick help Wiring Encoder
    Anyone one know where this extra ground goes on this D-808 encoder? Not mentioned on the lead specs or the encoder wiring diagrams (common Gnd?), blue & black have been swapped over since picture, see below..
    https://www.cnczone.com/forums/attac...d=406780&stc=1
    24221
    Re: Quick help Wiring Encoder
    EGND normally means Earth Ground and if so should be connected to the service ground conductor, it should not be used for current carrying conductor.
    Al.
    Albert E.
    May 2016
    12
    hmm,
    The encoder cable goes to motor via the port end, wiring diagram doesn't show this 2nd common that's a larger gauge wire. There is no continuity of this to the outer port housing.
    Any ideas anyone?
    https://www.cnczone.com/forums/attac...d=406798&stc=1https://www.cnczone.com/forums/attac...d=406800&stc=1
    May 2016
    12
    Maybe this black 7th wire is a Sheath wire for earthing? i suppose ill have to check all the port holes for continuity. Any idea's anyone?
    May 2016
    12
    Sorted, just checked with the supplier, The extra black wire that is thicker than the other 6 encoder wires is in fact the shield for the cable and should be earthed to prevent interference. :idea:
    Jul 2007
    1602
    Your wiring does not match the diagram... Black and blue are transposed.
    bob
  1. Need help with encoder wiring
    By Deano36 in forum Servo Motors / Drives
    Last Post: 02-25-2010, 01:40 AM
  2. looking for good wiring quick connectors
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 02-08-2010, 06:49 PM
  3. Quick Stepper Wiring Q
    By kawazuki in forum Stepper Motors / Drives
    Last Post: 08-21-2008, 05:11 PM
  4. Pic encoder wiring A B i and T
    By gurvy in forum PIC Programing / Design
    Last Post: 08-16-2007, 02:03 PM
  5. Encoder wiring
    By balsaman in forum Gecko Drives
    Last Post: 12-30-2003, 06:01 PM
