586,052 active members*
4,055 visitors online*
IndustryArena Forum > Manufacturing Processes > Other Manufacturing Processes > Stainless steel round bar available in Both Polished and mill finish
Results 1 to 1 of 1
    Dec 2018
    We are specialist distributor, processor and suppliers of stainless steel round bar in grade 302, 420, 455, 422, 431, 301, 310, 303 and 410 stainless steel in all finishes. We suppliers and manufactures of ss round bar in India which is made by world’s leading mills such as Outokumpu, Tayssenkrupp, Mukand. We cut to size of SS Round Bar Manufacturer in India, with both narrow and wide widths.
    An ISO 9001:2008 Certificate Company, Super Metal Manufacturing Co. Leading Stockholder, Suppliers, exporters of stainless steel round bar. Stainless steel round bar are cut to your specifications and supplied with complete set off mill test reports. Custom length and width can be available. Exports in your specialty! We can source hard find to grads and or non standard sizes to meet the special requirement to our customers. All the SS Round Bar can be cut to the size with the help of our extensive expertise in processing steel bar products.
    What is stainless steel round bar?
    Stainless steel is iron-based alloys containing minimum of about 10.5 chromium this from a protective self healing oxide film which is reason way this group of steel as their characteristics “stainlessness” or corrosion resistance.
    Super Metal Manufacturing Co. is one of India’s leading manufacturers of high quality Stainless Steel Round Bar is have ability of the oxide layer to heal itself means that the steel is corrosion resistant. SS Round Bar is depend on the presence of chromium other alloying elements are often added to enhance their properties
    Specialized In Following Grade of Stainless Round Bar
    We are distributes of top quality stainless steel Round bar, we high quality manufacturer of SS Round Bar in Maharashtra and Gujarat to customer in India and worldwide. Super Metal Manufacturing Co. is most trusted ss round bar suppliers. We will deliver immediately! We are specialized suppliers of SS round bar in India.
    Stainless Steel round bar packaging
    Please don’t worry that our products are packed stored transported according to the International regulation. We do care about the quality of our products; even some little details are paid attention to.
    Each other is packaged according to the customer’s standards including preparation for export such as wooden case, pallet or according to customer’s requirement All shipping documentation is provided for stainless steel round bar delivery from mill to customer.
    Every assignment begins with a visit of our experienced sales representative who assesses the volume / weight of the belongings and brief the client about the nature of packing required as well as various documentation formalities when moving from India.
    Stainless Steel Round Bar Supply Area:
    Our target market is the international market every year we export most of stainless steel round bar to countries like Indonesia, Malaysia, Singapore, Saudi Arabia, Qatar, UAE, Iran, Iraq, Oman, South Africa Nigeria, Kenya, Italy, UK.
    Stainless Steel Round Bar Marking
    Our products like stainless steel round bar are packaged to make sure that there’s no damage throughout transit. Just in case of exports, customary export packing is completed in wooden boxes or cases. All stainless steel round bars are marked with trademark, Grade, Size, and Lot No. On requests we can do custom marking on our products.
    The full identification of the Round Bars should be continuously marked down its whole length, including:
    Domestic Supply Destinations for Stainless Steel Round Bar
    Super Metal Manufacturing Co. is one of the largest exporter, manufactures and suppliers of stainless steel round bars in Mumbai which find application across diverse sectors. Products reliability and performance has made Super Metal Manufacturing Co. a leading exporter and distributor of ss bar in Mumbai as well as all major Industries areas and cities
    Stainless Steel Round Bar Useful Information
    Stainless steels have traditionally been divided into types depending on their micro-structure at room temperature, which gives a rough indication of new stainless steel is made from remolded scrap metal, rendering it an Eco-friendly material. Products dusts from processing
    Stainless Steel Round Bar are ideal for applications where sanitation is critical or where there is a constant risk of corrosion. Stainless steel does not rust, and so it does not need protecting from moisture or chemicals in its immediate vicinity. It will not need panting or finishing, and does not easily domestic and global clients.
    As an acclaimed enterprise of the industry, Super Metal Manufacturing Co. is involved in offering a vast array of stainless steel round bar as a manufacturers, exporter, stockiest and suppliers to our domestic and global clients.
    Super Metal Manufacturing Co. is one of the largest exporter, manufacturer and supplier of stainless steel round bars in India. Stainless Steel Bars, many perhaps be considered for an extensive range of applications where one or more characteristics are significant. These stainless steel bars are used for several applications such as Heat exchanges, condensers, process engineering, and Control Lines Medical implants (including Pins, screws and implants) Umbilical’s, High Performance Liquid Chromatography (HPLC), Semiconductors, and more.
    Types of stainless steel
    There are over 150 grades of stainless steel, of which fifteen are most common.
    The AISI (American Iron and Steel Institute) defines the following grades among others:
    -200 Series-austenitic iron-chromium-nickel-manganese’s alloys
    -300 Series-austenitic iron-chromium-nickel-manganese grades among others:
    Type 301-highly ductile, for formed products. Also hardens rapidly during mechanical working.
    Type 303-free machining version of 304 via addition of sulfur
    Type 304-the most common; the classic 18/8 stainless steel
    Type 316-Alloy addition of molybdenum to prevent specific forms of corrosion
    -400 Series –ferrite and martensitic alloys.
    Characteristic of Stainless Steels
    The characteristics of the broad group of stainless steels can be viewed as compared to the more familiar pain carbon “mild” steels. As a generalization the stainless steels have:
    • Higher work hardening rate
    • Higher ductility
    • Higher Strength and hardness
    • Higher hot strength
    • Higher corrosion resistance
    • Higher Cryogenic toughness
    • Lower magnetic response(austenitic only)
    • Must retain corrosion resistant surface in the finished product.
    Standard Classifications
    There are many different varieties of stainless steel and the American Iron and Steel Institute (AISI) in the past designated some as standard compositions, resulting in the commonly used three digit numbering system. This role has now been taken over by the SAE
