586,398 active members*
3,073 visitors online*
    Nov 2018
    Post problem with axis
    Dear friends i have problem with Weihong NK105
    in 3d machining the Z axis after some steps comes up and some time in the X,Y do shift thank you in advance of your answer
    Apr 2004
    5742
    Re: problem with axis
    You're losing steps. Try reducing your acceleration value by half and see if things improve.
    Andrew Werby
    Website
    Quote Originally Posted by jafar45 View Post
    It is better to use AC servo motor and driver, which will be more accurate, the cost are not so big different.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Hello, friend,
    Is your machine working with stepper motor? We also met same problem before. Did this happen after the machine working for very long time?
    If so, this is not the problem of the NK105.
    Jinan UnionTech Machinery Co., Ltd.
  1. Replies: 1
    Last Post: 11-24-2017, 03:56 AM
  2. Problem with VSD-E in DualDC drive mode, axis 1 works but not axis 2.. any ideas?
    By bmquist in forum CNC Machine Related Electronics
    Last Post: 08-31-2014, 04:08 PM
  3. Z axis problem.
    By hoops1888 in forum Mach Software (ArtSoft software)
    Last Post: 07-02-2013, 07:14 PM
  4. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  5. TC-22 z axis problem
    By gmagnuson in forum Bridgeport / Hardinge Mills
    Last Post: 03-14-2008, 03:36 PM
