586,114 active members*
3,279 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Diameter, Pitch, Number of Teeth, etc. on Spur gear?
Results 1 to 16 of 16
    Apr 2006
    4
    So im looking to acquire my spur gears and racks, but im a little lost as to what size I should get. It will be a direct drive set up for now. Ive heard the common is 24 pitch but what about number of teeth, diameter, etc.?
    Mar 2007
    534
    Have a google for diametrical pitch, 24dp is quite fine, metric gear pitches are given as a Modulus.
    Mar 2006
    759
    I would look into getting a spur gear with as few teeth as possible, if you are direct driving it.
    A 20 tooth, 20 pitch, 20 degree PA would be the best bet. Much smaller and you will run into issues with the teeth undercutting.
    www.mcmaster.com has the rack and spur gear
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Jul 2006
    64
    Massajamesb, for the Gear and rack you recomended above, at what gantry weight/servo power/speed does the chance of striping teeth start to be a concern? or is this ever an issue at all? I am looking around 100 lbs gantry with Tom C's 850 oz servos(dual drive) and around 10:1 reduction for a plasma table I am building.
    Doug
    Mar 2006
    759
    Quote Originally Posted by Perp View Post
    Doug
    Honestly, I need to weigh my gantry, but it is a heavy steel gantry. The gears/rack I am using are pretty heavy duty, and I have noticed no wear so far, and that is a lot of use
    I would imagine if you had a 300 + pound gantry, and a really poor bearing system, then stripping teeth would be a concern. Other than that, I don't see any gear stripping problem, but then again, that is one of those subjects I am a bit ignorant on
    I would think since there are no cutting forces, and the gantry is rolling smoothly on bearings, wear would be minimal at best.
    Hope that helps a bit.
    -RedGreen show.
    Jul 2004
    595
    Are you using direct drive on your system? If so, are you happy with the accuracy?
    David
    Mar 2006
    759
    No, I have a 15 tooth pulley on the motor, and a 40 tooth pulley on the 20 tooth driven gear. Roughly a 1:2.66 ratio. I do not recommend direct driving your machine. The downsides outweigh the upsides.
    I am quite happy with the accuracy, although I am using plasma.
    I can honestly say that the machine is way more accurate than the process I use.
    -RedGreen show.
    Mar 2006
    759
    Doug
    Perp, I weighed my gantry (roughly), and altogether, gantry, carriage, torch, Z axis, motors, motor mounts yadda yadda, everything mounted on that axis, comes out to right around 80 pounds.
    The thing to remember is that your spur gear doesn't really see that weight directly, as the weight of the gantry is actually on your bearings. What the spur gear "sees" is the force needed to move the gantry forward/backward, and then come to a sudden stop when neccesary.
    This is not enough force to strip the spur gears that most of us are using, as long as your gantry is able to move smoothly.
    -RedGreen show.
    Jul 2006
    64
    Thank you for your efforts. I do think all of the great info you guys have shared will help me (and countless others) build better machines than we ever could on our own.
    Soon I will begin a build log of my own. I have a computer and all of the electronics, now its time to start buying the steel and linear motion components.
    Thanks again
    Doug
    Mar 2007
    534
    There is no escaping the simple fact that 1 pound force will accelerate a mass of 32.16 pounds at a lowly 1 ft/s/s.
    Even monster sized motors can't give instant acceleration and constant feed rates can only be approximated.
    So, how low can our accelerations be before the cut becomes compromised?
    I just switched table design to racks to eliminate twist, and discovered pi had suddenly sneaked in to the equasion.
    Confidence truly is that feeling you get just before you understand the problem
    Nov 2008
    4
    Hello. I am very new with cnc machines. I am building a 24" x 36" cnc machine out of aluminum stock. Linear motion will be done on ball bearings driven by a gear rack and spur. the motor kit that i am using will be from this link. http://www.probotix.com/3_axis_stepp...or_driver_kit/
    my goal is to cut cast aluminum parts. the only problem is im very confused on what ratios to use when i choose my gear rack and spur. I am getting mine from mcasters but there are so many choices and i am not comfortable to make this desicion on my own. can anyone that knows more about this advice me on the proper set up, thank you.
    Jul 2005
    2415
    the ratios (number of teeth) are of less concern than the DIAMETER of the "spur" (Pinion gear). The linear speed of the pinon is PI (3.1416) times the DP of the pinon gear.
    Here is some quick math:
    A 1" pinon moves 3.14 inches per rev...in essence a 3:1 STEP UP. That buys you 3 times the speed (about 1800 IPM off a direct coupled stepper) but costs you 2/3's of your torque and resolution. Since you start out with .005 per step resolution that carves it down to .015 per step. Coupled with the other errors (backlash, flex, etc) your accuracy will be less than .030
    I know it's everybody's goal to build the cheapest table they can, but if you end up with a machine that won't do it's intended job then you have wasted your money.
    The drive kit you listed is not a bad value at that price but beware that those drives are based on an older chip that is limited in speed and current and has no input isolation. It also offers none of the features you will need for plasma and you are on your own to deal with the noise and ground loop issues.
    TOM CAUDLE
    www.CandCNC.com
    Nov 2008
    4
    drive system
    i appreciate your advice, and it was informative. but if it was you, and you had to choose the system, and controllers, steppers, what would you use? im understanding that there are negative flaws with the system i was looking at, but if you have any advice let me know. Im trying to accuratley mill aluminum castings. I have noticed that some people use screw drive systems instead of gear racks, is that a good idea? As of now i was going to gear up that motor with 1:3 ratio to give it extra tourqe, i did the timing with pinions and mounted bearings (designed a timing box in essence). Any help is appreciated. Thank You.
    Jul 2005
    2415
    I'm confused. You posted in the Plasma Cutting section and the assumption was you were going to cut using plasma. Your last post talks about milling and accuracy...totally different subject and CNC approach. Leadscrews and plasma don't mix well. They work fine for milling. I won't give advice on controllers or electronics on list because those are products I sell.
    So do you want to do milling (maybe in 3D) or cut flat casings with plasma?
    TOM CAUDLE
    www.CandCNC.com
    Nov 2008
    4
    help please
    Im interested in 3D milling. I work on motorcycles alot and want to be able to cut parts for certain applications. I am hoping to take aluminum castings and have a cnc machine do automated milling. I am very good with cad and have good math skills. I figure with the right resources I can build a cnc to suite my needs. I just dont want to invest in a design without confirming its going to work properly, in a mathmatical sense. At this point im looking for technical data and resources that will help me better understand the calcualtions on speeds and feeds, rpm and torque values, ect. maybee some charts explaining requirments on different alloys, things of that nature.
    For example, when I am choosing a recirculating ball nut shaft, how do I choose the right diameter and pitch, ect. or when gearing up a stepper motor, how to determine the right ratios for the design.
    The issue I am having is finding a resource for this information, if you know of a fourm, website, or even a book with such data, let me know. Thanks.
    Mar 2008
    29
    help please
    All of the information you require is scattered throughout this forum - read read read!!!
    Also check out the MechMate Forum, without a doubt the most complete and detailed CNC Router/Plasma Table plans and build logs on the Internet. Every detail of building a 4'x8' (size can easily be reduced or enlarged) gantry style router table.
    http://www.mechmate.com/
    I should also mention that the site is run by one of the most giving people I have ever come across on any forum.
    Good Luck with your design and build.
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  2. Spur gear availability?
    By 2fst4u in forum Waterjet General Topics
    Last Post: 04-02-2007, 02:46 PM
  3. Spur Gear / Gear Rack
    By ckrantz in forum Linear and Rotary Motion
    Last Post: 12-07-2006, 06:06 AM
  4. Gear Teeth thickness problem.
    By nikolatesla20 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-09-2005, 07:39 PM
  5. gear pitch
    By 2muchstuff in forum Mechanical Calculations/Engineering Design
    Last Post: 04-02-2005, 03:04 PM
