587,048 active members*
3,098 visitors online*
    Mar 2008
    60
    Interact 1 MKII TNC 2500
    I have had one of these for several years for my home shop use. I had not run it in several months, maybe close to a year. I get a Gross Positioning Error Y C. I checked the motor cables, brushes, took the encoder apart and checked connections. Tried changing the voltage at parameter 1140. I decided to home Z and X and let Y warm up. In a few minutes I smell smoke and kill everything. A resistor is burned up and maybe the transformer on MT1-1 board. Probably repairable, but second time, different resistor. Another periodic problem is the KTK drive errors out if you try to run a high RPM, I have to step it up in the program. I am so sick of this stuff. Should I rip all the electrics off? I like the Heidenhain control and have a good programming system. The machine is extremely low hours and mechanically excellent.
    What to do????
    1121
    Re: Interact 1 MKII TNC 2500
    If you let the smoke out of the drive card, then you need to have it repaired or get a replacement
    the KTK drives are a pain I hear, but if it works mostly....
    the control itself is pretty sturdy, but the attached electronics sound like they are letting you down
  1. Bridgeport interact 1 MKII, parting out value
    By BrianP in forum Bridgeport / Hardinge Mills
    Last Post: 01-09-2015, 12:36 AM
  2. Software for BP Interact 1 mkII
    By Harb in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2009, 10:19 PM
  3. Cheap CAM for Bridgeport Interact 1 MKII TNC155
    By Duncs in forum Uncategorised CAM Discussion
    Last Post: 09-03-2008, 10:08 AM
  4. Interact 1 MKII 4th axis problem....?
    By DuncanRitchie in forum Bridgeport / Hardinge Mills
    Last Post: 08-23-2006, 03:05 AM
  5. Bridgeport Interact 1 MkII problem
    By sparsrus in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2006, 09:53 PM
