586,121 active members*
3,100 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > My first CNC router: 1.5 years building
    Aug 2003
    15
    Smile My first CNC router: 1.5 years building
    My small CNC router is finally working after 1.5 years in the
    making. It is stepper & lead screw driven and cuts are done
    using a HF trim router,...need more horses, but it works.
    The machine was built using an Atlas/Craftsman 104... 6 inch
    bench lathe and a HF 12" drill press. Has 3/4" linear bearing on
    all three axes, lead screws are 1/2" 0.100 double start anti-
    backlash acme type. All of the steppers and linear bearings
    were purchased surplus.
    I said it was small, here's the specs:
    X=12.5, Y=12.5Y, Z=3.5, that's inches/imperial.
    X-stepper, #34 Vexta 2-phase, 4-wire, 220 in-oz
    Y-stepper, #23 Slo-Syn 2-phase, 6-wire series connected, 65 oz-in
    Z-stepper, #23 EU 2-phase, 6-wire series connected, 90 oz-in
    Camtronics XYZ controller with micro-stepping, 60 ipm all axes
    TurboCNC is the control program running on an Intel MMX CPU
    w/networking
    It has been a fun project. I've been a Software/Hardware
    Engineer for many years so the electronics build went smoothly.
    In a previous "LIFE" I was a Journeyman Machinist for 12 years.
    All of these skills were used in fabrication of the various parts
    and pieces used in the assemblies.
    I just started using BodCAD-CAM V18 for the toolpath generation.
    I'll see how this goes as compared to the other CAD-CAM
    software I have evaluated over the last 1.5 years.
    My first project is a large wooden clock from the Brian Law’s
    Woodenclocks web site. Some great plans sets, but you need to
    rescale the DXF drawings to a size you can easily build. Alot of
    gears that can be made using a CNC router.
    I posted some pictures of the router in the gallery.
    BTW, I have some good left over parts that can be used in
    building a small router. i.e., linear bearings & rails, lead screws
    and a number of different #23 stepper moters. I'll post these
    items for sale on this web site in the next day or so.
    Harley
    Apr 2004
    26
    Harley, are there any suppliers in the NW that you'd recommend (for anything)?
    Aug 2003
    15
    kcoaks,
    I used McMaster-Carr for my lead screws: Precision-Modified
    Acme, 303 stainless, 1/2" dia, 10 pitch, 2-start, 5 TPI, 48" L
    MC Part#: 6350 K22, $128.43, unmachined. The Wear-
    Compensating Nut: #6350 K62, $32.73
    I chose the 1/2" diameter lead to fit through the head stock of
    my lathe so I could turn the ends for bearings and couplings.
    I guess I could have used a larger diameter lead and made an
    end adapter for the ends. This way the lathe was not the bottle-
    neck. I think one needs to use a good grade of lead screw & nut
    if accuracy is the goal.
    The linear bearings and shafts were bought via eBay auction
    items that had bearings, shafts & stepper motors. The auction
    prices were from $100-$200 and I got all of the bearings, etc.
    in two buys.
    Good luck on your project, Harley
  1. Building a CNC router
    By HomeCNC in forum CNC Wood Router Project Log
    Last Post: 10-18-2009, 12:56 PM
  2. purchase or building a home cnc router.
    By s_bedow in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 07:22 AM
  3. Books on building CNC Router?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 08-06-2004, 01:48 PM
  4. How many building the cad cut cnc router?
    By jsatter in forum DIY CNC Router Table Machines
    Last Post: 07-26-2004, 09:10 PM
  5. Got a jump start on building materials for my CNC Router
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 11-17-2003, 02:13 AM
