Re: zeroing in on components
What the cut charts don't tell you is that for plasma acceleration is king! The laws of physics will see significant slowdowns when cutting which will cause a whole host of cutting problems and only some can be corrected if you have Corner lock/Velocity Anti Dive. If you have a 100 lb gantry those features won't solve your problems. Expensive high performance servos may get you over the line. Robert has nailed it! The design parameters for routing and plasma are totally different. Best to just pick one and design for that.
Rod Webster
www.vehiclemods.net.au
